Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
Print head slams back and forth?
Printer head slams back and forth and 5100 error occors
SOURCE: cananon iP90 error 5100
have the same message posted need to know ASAP!
Posted on Aug 27, 2008
  • 421 Answers
SOURCE: Everytime I try to print Error 5100
Hi, Error E22 5100 is a carriage error. Check that nothing is stopping the cartridges from sliding back or fore acroos the silver bar inside the front of the printer.
Posted on Nov 08, 2008
  • 1335 Answers
SOURCE: Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
Posted on May 05, 2009
SOURCE: CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Posted on Oct 29, 2009
pineworks
  • 4041 Answers
SOURCE: printer orange light flashing 2 and 5 times, servive error 5100
Hi You can Try 2 things.
All the luck for you
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Mx 316
Error 5100 typically means that something has jammed the carriage. Unplug printer, open, and examine the print area for anything that might be blocking the print heads from moving back and forth. clear...
Sep 07, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Pixma mx452 error 5100
In my case the printer head was going all the way to the left and ending up "stuck" there. The print head could still be moved easily from left to right manually but when you turned the printer on it ended on the left side and I got the 5100 error.
I turned off the printer and disconnected the power. I took a flash light and carefully inspected the clear ribbon. In the middle there was a bit of goop on the clear "timing tape", about 1cm long. I used a clean paper towel with a bit of alcohol on it along with a rubber coated pen to keep everything away from the grease on the track and gently hold the ribbon in place while I cleaned the goop off of the tape. After that the 5100 cleared and the printer is working again.
It looks to me like the clear tape is just an indexed strip that's used to tell the print head how far it has moved. With some of the index obscured by the goop the print head thought it hadn't traveled as far as it had because it was reading fewer lines in the index. The goop was probably some grease from the track the print heads go back and forth on. Not sure how it got on the tape, but cleaning it off solved the problem for me.
I have no idea what the long term effect of ink on the plastic tape will be, but it got the printer working when I needed it and saved me from having to have it professionally repaired.
Nov 08, 2013 | Canon Office Equipment & Supplies
The 5100 error won't go away. The inks slam from
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
Jun 26, 2010 | Canon Pixma MP480 All-In-One InkJet...
Trying to print and I get this error 5100 says to cancel print and turn off printer and turn back on. Does the same thing and can't find manual
5100 says something is blocking the carriage assembly froom moving back and forth properly. Either paper scraps on one end of the printer or just something inside that doesn't belong. Try opening the cover til the inks come to the center and unplug. Try moving the carriage back and forth and look especially on the right side for scraps. If OK clean the encoder strip with q-tip and alcohol.
Feb 08, 2010 | Office Equipment & Supplies
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Thanks.
May 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printing problems
I've seen the head banging problem before. If the printer is out of warranty the only solution is replacement.
Nov 11, 2007 | Lexmark Z53 Color InkJet Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
old marine
old marine
