Rca drc96090 screen dark
My portable rca dvd player makes loud sound when playing dvd dvd player # drc96090
the cd is touching the base while it is spinning...i came across a similar problem and used a flathead screwdriver and gently pry the cd plate upwards so there is a little space ...otherwise take it to a repar shop...
Nov 03, 2013 | RCA 20F610TD TruFlat TV/DVD
TV screen is dark
If the picture is dark then I suspect a bad lamp if you just replaced it...
Nov 20, 2009 | RCA Televison & Video
RCA DRC6338 screen is dark
There can be dead lamp or invertor. Give it for some special guy who can fix this.
Aug 08, 2009 | RCA DRC6338 Portable DVD Player
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
Color on the picture is dark
You can adjust the brightness on the back of the set which says screen. put a mirror so you can see the screen and slowly turn the screw clockwise until you can see the picture.
Jul 10, 2008 | RCA F36650 36" TV
No Picture
where can i buy Deflection board for RCA D52W20
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dark screen and no green conv. RCA P52926 52in Rear Pro
I would first check for liquid on the board, if ok then tap on the green board see if theres a loose connection on the board
and then tap on the convergence area see if loose connection there.
Jan 20, 2008 | RCA P52926 52" Rear Projection Television
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
