Crosley cr703 cd drawer will not open
Cd drawer will not open
5 Suggested Answers
SOURCE: cd drawer will not open. Crosley CR248 unit
Yes, there is i've done it before. You have to either open the back or the bottom it depends what cd player you have. then you will see the cartridge with the CD on it, take a thin long objects or something sticky and pull gently on the CD. It may take sometime but if you do it right the CD will com out with no scratch.
Posted on Dec 31, 2009
sonicboomele
  • 1557 Answers
SOURCE: have Crosley CR245 the CD drawer does not open. H...
it sounds like the unit has a broken open door belt take the lid of and look for a black broken belt you can replace it with a rubber band of the same size
Posted on May 15, 2010
gopakumarg43
  • 74211 Answers
SOURCE: CD drawer will not open
Hello
There is a loading belt that fastened with a loading motor pulley, which gets the CD tray in and out. If this belt or the loading motro has trouble, the CD tray wont cole out, or load in properly. You have to check and find out which part is faulty. In normal cases, replacing the loading belt will rectify this problem. OK.
Posted on Dec 26, 2011
AndrexT
  • 15171 Answers
SOURCE: How to manually open eject Crosley CR248 CD drawer
Look at the front of the tray for a small pin hole. Open up a paperclip with pliers so that it is nice and straight. Insert it into the pin hole and push firmly. The tray will pop open enough to be able to pull the drawer manually.
Posted on Nov 10, 2015
Nov 10, 2015 | Crosley Audio Players & Recorders
Crosleycd disk will not eject
To manually open CR 248 CD drawer take a butter knife insert it under the drawer and above the "C" in the word CD recorder. I polked around for the button and it opened. Did this several times and it's working now thanks to another post on Fixya.com! Yay!
Sep 14, 2014 | Crosley CR2405A Mini Audio System
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Sometimes the cause is a belt that has either broken or come off. If you need a new one just measure the diameter of the old one in MM. The put that into Google with the words "drive belt" and find the one close to your stated size.
Feb 21, 2013 | Crosley CR248 Turntable
Cd drawer won't open
This is a belt driven tray transport- you need a new belt installed. I just worked on one for my aunt recently.
Dec 08, 2012 | Crosley Celebrity CR73-3 3-Disc CD Player
Hello
Dec 25, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Cd drawer wont open cr248 songwriter
I have the Crosley CR247 which is the same except for style. I had same problem.
The CD drawer stuck and would not open. It made sounds like it was trying. I could not find any information on a solution, but from what I had been reading on other CD Drawer problems, it sounded to me like there had to be a manual emergency release somewhere. Could not see one anywhere on the unit, so I took a butter knife and inserted in the crack just below the tray. I slide the knife from left to right and just very gently ppressed around with it. When I had it over to the far left hand side moving it over just about an inch and a half to two inches, I just slid the knife from side to side and it opened. Sorry, I am not a mechanic or do not know how to fix things, so this is the best that I can do to explain where the emergency release is located. My little rubber belt drive looked good, so that wasnt the problem. I just opened and closed my drawere about five or six times before I felt that it was safe to stick CD in. I don't use it much, maybe that was the problem. The trick is getting the darn door open first so that you can see if it is the belt drive or not. Good Luck to anyone with the same problem.
May 03, 2011 | Crosley Songwriter (CR248) Shelf System
Have Crosley CR245 the CD drawer does not open. H...
May 13, 2010 | Audio Players & Recorders
Cd drawer will not open. Crosley CR248 unit
Dec 31, 2009 | Crosley Songwriter (CR248) Shelf System
Crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Jan 22, 2008 | Crosley Songwriter (CR248) Shelf System
26 people viewed this question
 Grubhead
Grubhead
