Question about Pentair Water 473605 Pressure Switch Water Ht Pump (Pentair)
I need to adjust the pressure on a parts2o switch
How many turns to increase the water pressure 5-10 psi?
What causes my booster pump to increase pressure even after I shut power and or water supply off?
something wrong here. your incoming pressure is 4 psi ( tank pressure to the pump and you use a pump to boost pressure to a maximum of 65 psi at which point the pump is shut off ( all taps close off)
yet with no pumps running the pressure goes up to 100 psi
Find where you are getting pressure in that is making the pump leak
if you have 100 psi to the pump when it is turned off, then it would not be turning on ( power on) as the shut off pressure is set at 65 psi and the line pressure is 100 psi
Sep 27, 2016 | Grundfos MQ3-45 1 HP Pressure Booster...
Tip
Well Pressure Switch Adjustment Water Well Problems
1fa4b10.jpgIf you have a water well to supply your water needs, then you also have a well pump is some form and a well pressure switch that controls the water well pump and the pressures that it turns on and off at. Making the adjustments to this switch can be confusing, I will try to take away some of the confusion for you. There are many types of well pressure switches made. I will describe the adjustment of the most common type of switch and you can possibly translate from there if you have a different type of well pump pressure switch.
  1. Turn off the power to the well pump before making any adjustments. The blue flash from the arc when you short out the power is scary and leaves you seeing stars for a time.
  2. Drain all of the water pressure from the system and check that you have air pressure in your well pump pressure tank. If you intend to set the cut in of the pump at 30 PSI then make sure there is 28 PSI in the air part of the tank. Always 2 PSI less than your cut in pressure.
  3. Start the pump, run water, and then observe the pressures as the pump starts and stops. Remove power when adjusting to avoid the blue flash…you are working in close proximity to the electrical contacts of the switch.
  4. To raise the cut in pressure turn the taller center nut down to increase the spring pressure. This will start the pump at a higher pressure. To lower the start pressure turn the nut up or counter clockwise.
  5. To change the differential pressure, the difference between the start and stop pressures, you need to adjust the smaller nut that is on the side of the pressure switch. Turning this nut down will increase the differential pressure and likewise turning this nut counter clockwise or up will lower the differential pressure.
This process can take some time, but it will be worth it to have your pump and water system operating efficiently. You also can set the well water pressures to your liking.
This is a basic guide to help you fine tune your water well pump and your well pump pressure tank, along with your water pump pressure switch, so that they all work together to give you a good stable supply of well water.
http://www.fixya.com/support/r3689163-water_problems_pump_problems
http://www.fixya.com/support/r3690698-pump_problems_water_tank
http://www.fixya.com/support/r3690937-pump_problems_pressure_switch
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
on Dec 22, 2009 | Plumbing
Adjust pressure
The adjustment screw description-- is under the gray cover
The big spring is the general max pressure & cut off & initial setting
The smaller spring side is the twicking on the cut in or back on
They both work together in a way
Sounds like your using a well pressure switch-- on an air compressor
If so- then yes- you need a different switch for the application,
as the one you have is out of it's range
I set my compressor (single stage) at 80 & 135
Aug 12, 2014 | Square D PressureSwitch, 125-175PSI,...
I have a new 1 hp utiltech pump and a new. Precharged tank with 34 psi in it now. When i prime the pump the pressure goes right to 25 psi and i can hear some water moving . When i open the shut off valve...
The 34 psi of the pressure tank sounds high, but it depends on what the cut-in pressure is set at in the pump pressure switch. Typically the pressure switch is for 20-40 psi or 30-50 psi. To establish what the pre-charge of tank should be , you need to establish what the pressure switch setting are (i.e 20 - 40 psi , etc.) Run the water and watch the pressure gauge and note at what pressure the pump comes on. The pressure tank needs to be pre charged 2 -4 psi below that cut-in pressure. So if the cut-in pressure is say 30 psi, then the tank needs to be pre charged to 28 psi.
To pre charge the pressure tank, turn the pump off. Drain the pressure tank of water to relieve all pressure in the tank. Then check the pressure of the tank at the air valve. Set the pressure to 2 psi below what the cut-in pressure is.
If you adjust the pressure switch, say from 20-40 to 30-50, you will need to go through the procedure of re adjusting the pressure in the tank. I hope this helps....
May 21, 2014 | Plumbing
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Apr 21, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
Pressure switch
Remove cap from pressure switch (small nut on top). You will see 3 threaded studs with springs held down by nuts at the end opposite from wired connections. Avoid wired connections with tools and fingers! The center sprung nut adjusts the ON AND OFF pressure settings. Clockwise (tightening down on spring) increases the pressure setting. One of the outside springs controls nothing - note that it has no connection to the switch moving parts. The other one adjusts the OFF setting. So adjust the center one until the ON pressure is 30 psi and then adjust the OFF setting until the pump cuts out at 50 psi. If you have an expansion tank, set this to 2 psi below the OFF setting. (If you have manual for the pump, check the pressure settings in the tables given for your pump.)
If this isn't what you need, please post more info!
Oct 12, 2010 | Flotec 1 Hp Deep Well Pump
Increase water pressure
if you go to the pressure switch inlie (shouldbe within 6 feet of well head) you will ee a rubber plug in th top of it. remove the friction plu an there is an allen bolt under it. adjust pressure with an allen wrench there.
May 13, 2010 | Kitchen Appliances - Others
Lack of water pressure from gun
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up. Also, adjust the nozzle by turning it to increase pressure.
Apr 15, 2010 | Karcher PSI Electric Pressure Washer
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Pentair Water 473605 Pressure Switch Water Ht Pump (Pentair) Logo
29 people viewed this question
Top Pentair Garden Experts
Dennis Key
Dennis Key
john h
Are you a Pentair Garden Expert? Answer questions, earn points and help others
