Question about Polaris Pool & Spa
Dyna-glas filter basket replacement
Replacement basket
  • 717 Answers
You can find those baskets at many pool stores both online and brick and mortar stores.
Rod
US Parts Center
Posted on May 06, 2014
2 Suggested Answers
  • 13652 Answers
SOURCE: Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Posted on Apr 03, 2010
My WL80t65C has had the RPS replaced, now won't spin the Bowl, does first stage of wash cycle then does not spin the Bowl. Times out. Code 40! Any ideas?
Fisher Paykel Top-Load Washer WL80t65C Error 40
Error Fault Condition
- Spin Basket Will Not Engage Or Disengage From Clutch.
Repair or Check - The spin basket has to be able to rise and fall with the water level. This is to engage and disengage from the clutch. Unplug the washer from power. Remove the spin basket. Remove any objects found between the spin basket and the tub. An object could be interfering with the spin basket clutch engagement. Replace any broken drive components.
Parts for Replacement - Drive Components.
Sep 20, 2016 | Washing Machines
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
Replacement silverware tray
Best Dishwasher Replacement Baskets - Amazon.com
www.amazon.com/...Replacement-Baskets/.../2232353...
Amazon.com, Inc.2. GE WD28X265 Dishwasher Silverware Basket · 4.6 out of 5 ... Whirlpool 6-918873Silverware Basket · 4.7 out of 5 ... 4. Whirlpool 8531233 Silverware Basket.
Nov 24, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
Lg wd 10264
follow this steps and fix it. God bless you
  • The basket spider provides support and stabilization for the washing machine's basket. It is located at the back of the basket and has three arms, which are attached to the basket by three bolts. Although the machine's basket is made of stainless steel, the spider is not. It is composed of an inexpensive, white, aluminum metal, also known as "pot metal," which is subject to corrosion. Eventually, the aluminum or pot metal deteriorates to the point where the spider breaks during a wash cycle - accompanied by very loud noises. According to one repairman, the sound mimics that of a car collision. The amount of corrosion behind the basket can be enough to fill a pint container.
Life Expectancy
  • The spider basket in a front-load washing machine does not have a long life expectancy. According to the appliance repair website Suds and Service, pot metal basket spiders in small front loaders, those with a capacity of 16 lbs. to 17 lbs., have a life span of only five to six years. These short-lived basket spiders are found on several washing machine brands, including Kenmore, Frigidaire, Electrolux and White-Westinghouse, as well as Gibson, Tappan, Wascomat and some GE washers.
  • Sponsored Links
Replacement
  • Replacing a front-loading washing machine's broken basket spider is expensive. Although the spider is removable from the basket, washing machine manufacturers do not sell the spider as a standalone part, so you must purchase an entire basket. At the time of publication, the price of a basket and spider ranges from $259 to $470 depending on the manufacturer. When combined with labor costs, replacing the basket and spider can cost more than $600.
Read more: http://www.ehow.com/info_12176732_causes-basket-spider-break-frontload-washer.html#ixzz2aSx3lP95
Jul 29, 2013 | Washing Machines
We have a lsr7233 bwi or dwi top loader washer and the basket is getting big holes in it betty
Here is a link to the basket replacement. The price of the basket replacement may be a little to much cost wise for you and might be better to get a new washer. Let me know if you want to replace the basket and I could walk you thru the replacement process.
Jan 10, 2011 | Whirlpool LSR7333 Top Load Washer
I have a MieleG2142. One of the racks is not sliding smoothly which I believe I have narrowed down to one of the wheels in the rail guides not turning. How are the rail guides removed?
Hi dear.Try this.Pull the top basket towards you.Check on the side (if you can) back of the basket two of the wheels on top row should be on rail guide & third one just under the rail guide to support the basket.It should be even on both side of basket to run smoothly.If not pull the basket all the way towards you & lift up the basket you are holding.Basket will be free to come out of rail guide.(Please check,are the rail guides running in & out freely without basket?If not there are two plastic wheel inside of the each rail guide one or two of it must be damaged.That needs to be replaced.Please also check side wheels on the basket,they sould be freely turning.If not needs to be replaced.) If that did not work out,try to put back the basket even way to rail guide the way took it off.Contact Miele for assitants.Thanks.Goodluck.
Aug 07, 2010 | Miele G2142 24 in Builtin Dishwasher
Replacement basket for a Graco DuoGlider
Hello Carcuni,
Go to this link http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
You should be able to replacement parts for your duoglider.
Apr 28, 2010 | Baby Gear
Basket Strainer Specs Question
1\ Amount of free open area is the ratio of the open area through the strainer basket to the cross sectional area of the pipe. A good basket strainer should have a ratio of 4 to 1. 2\ Ease of basket removal is important because baskets may require frequent cleaning or replacing due to buildup. 3\ Compactness of the design saves you valuable space. A small strainer is less bulky and easier to handle. 4\ Availability of basket perforation sizes gives the strainers the flexibility to cope with a wide range of particle sizes.
Aug 27, 2008 | Moen 22174 Stainless Steel 2in. Basket...
Achiever CCS 5000 Basket
Did you contact Royal Corporation. Look up the model on EBAY and you can find a replacement. I have a used basket from a customer that did not want to repair their shredder. You can have it if toy want to come to Clearwater Florida
Jul 11, 2007 | Achiever CCS5000 Shredder
Pool & Spa Logo
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
