Question about Hama Alpenpod Walking Stick / Monopod For Dslr Cameras
Antishock open too far
I HAVE UNFORTUNATELY OPENED THE MIDDLE SECTION TOO FAR AND NEED TO LOSE IT TO CLOSED LENGTH. HOW DO I DO IT
Every time I open the door it hits the fender And makes a popping sound !
the hinge could have been bent in an accident but you can try shims where it bolts to the frame to give you more leeway.
Jan 22, 2013 | Vehicle Parts & Accessories
Just quit working
I assume there is no display at all. First make sure there is power to the microwave. Next would be the fuse INSIDE the control section. It needs a 15 Amp slow blow fuse. If that is the problem and you replace it (first disconnect oven!) and the oven works Ok that sould have taken car of your problem. However to do a little test you could, after having replaced the fuse, open and close the door several times. If it blows the fuse again that means that there is a problem with the door switch sequence. I don't know if you want to go this far, but there is one "normally closed" switch that, when closing the door, needs to open before the "normally open" switches make contact. Conversely when opening the door the "NO" switches need to open before the "NC" switch makes.
May 08, 2011 | Microwave Ovens
How can i make cake in grill type ovan
Just about any gas grill can be used like an oven. In fact, just about any thing you bake in an oven can be baked on a gas grill using the indirect cooking method.
All you have to do, is preheat the outer burners (one on the right and one on the left). That's assuming you have a 3 or more burner gas grill. to the proper temperature that your recipe calls for. When I say, "preheat", I mean with the grill hood closed. This may take a little longer than what your kitchen oven would. In the meantime, prepare the cake batter according to the recipe's instructions. Once the grill has been heated to the proper temperature. place the cake pans in the middle section of the grill, close the hood and bake the length of time required in your recipe.
Try no to peek to much, as each time you open the grill's hood, you'll lose as much as 20 degrees in temperature. Use time and your nose to determine if the cake layers are done.
All of the above is based on using the grill you listed above. Coleman LG20510E
Happy Grilling!
Feb 25, 2011 | Coleman LG20510E Grill
Garage door opens randomly at anytime. Opened sometime in the middle of the night and I find it about 5 AM the next morning.There are times when you close it, and then it opens again after completly...
This sometimes happens when the door is traveling just a bit too far downward, hits the floor and the safety causes it to reverse and open. Locate the 'down limit' on the side of the motor unit and turn it just a little in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Sep 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
My ink jet cartridge is too far to the left side of my printer to replace it with a new one. How do I get it to the middle where I can remove it and put in a new one
You need to replace the cartridge when the printer is ON. When the printer is ON, as soon as you open the front cover to get access to the cartridge, they will be moved to the center of the printer, so that you can replace them.
Apr 01, 2010 | Lexmark X2350 All-In-One InkJet Printer
Garage door is going down too far
Use a flat blade screw driver to adjust these limits by inserting it in the holes as labeled . Start gradually adjusting and stopping the travel if needed by pushing the open/close control as per usual.
Aug 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
May 14, 2009 | Canon Prima Super 105X - Point & Shoot /...
Chrysler T&C Power Door Problem
If it stops in roughly the same spot every time, and won't respond after it has stopped, it sounds like a broken wire. It is likely losing its electrical current to run the motor. It should be right where the track bends when the door has stopped. Check for loose or frayed wiring inside the flexible plastic track just below the door. The wires will often wear after being bent over and over again. If you find a broken bit of wire, cut out that section and splice in a new length of wire. Be sure you do a good job splicing, or you may end up with the same issue again soon. I am not a mechanic by any means, this just makes sense to me, and I'm considering buying an 01 town and country with this issue, which is why I'm on this site to begin with. Best of luck -
Jan 22, 2009 | 2008 Chrysler Town & Country
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
How to open case of Acoustimass module
Just a bit more info...a bit more detail
Remove the two screws from the case at the back.
Sit the unit in normal upright position. Use a good torch and look at the back of the unit along the top seam where the plastic case joins the main body - there are three latches to disengage along this seam.
1. The thumbwheel which turns to the left & exposes the tab. This disengages a simple Tee'd section on the wheel which stops the case sliding down. As long as you can see the tab this is disengaged.
2 & 3. On the far left & far right of the seam are simple lever latches which must be pushed back towards the main body to allow the rear case to slide down. Push these in then the case will slide down quite easily.
Sep 01, 2007 | Bose Acoustimass 15 System
Hama Alpenpod Walking Stick / Monopod For Dslr Cameras Logo
59 people viewed this question
Top Hama Photography Experts
Tony
Are you a Hama Photography Expert? Answer questions, earn points and help others
