Question about Stanley Hardware & Accessories
Program remote Stanley 31171 - Stanley Hardware & Accessories
I have a Stanley garage door opener, not sure of model, maybe 88426. Thats the only number i can find on it. I need to program a generic remote but no clue to settings
You will need a universal remote and use the part of the directions for dipswitch's. You will find a row of small white switches on the back of the motor and the remote will need to match it. If you have another working remote you can get the switch sequence of the remote instead of the motor
Jun 03, 2017 | Building Materials
Program a stanley 2811
Request programming information directly from Stanley.
Dec 12, 2014 | Stanley Hardware & Accessories
How do i program stanley radio transmitter model 28070T
U will have to get your manual or go online to Stanley and reprogram the remotes.
Nov 30, 2014 | Vehicle Parts & Accessories
How to program the Clicker garage remote to a
Go to garage door opener with the remote clicker..somewhere on the opener there is a learn button push it an a led light will stay on.within 20seconds push an hold the button on the remote till it goes out
Oct 05, 2014 | Building Materials
How to program a universal gate remote ?
If you still have the remote that came with the gate controller then you simply match switch positions on both remotes. If that isn't possible then you must open the gate actuator to expose the receiver in it to see what position the switxhes are in then set the universal to match. Be aware that all universal remotes may not have enough code combinations to work. If that's the case then you'll have to get the correct remote for the gate actuator.
Jun 06, 2014 | Multicode Stanley One Button Gate Remote...
Am programming Toyota Camry 2008 model key less remote with SBB key programmer Tool,But when ever,i get to the final stage to register remote to ECU after pressing lock and unlock at the same time on the...
If there is a communication problem, You run the risk of triggering an anti-theft function in the ECU resulting in disabling the ignition. Your best bet is to have the dealer program the fob
May 30, 2017 | Toyota Cars & Trucks
Hardware & Accessories Logo
43 people viewed this question
Top Stanley Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Sean Fick
Sean Fick
Level 1 Expert
Are you a Stanley Hardware and Accessory Expert? Answer questions, earn points and help others
