Question about Lowrance LMS-332C GPS Receiver
Gps not responding on my lms332c - Lowrance LMS-332C GPS Receiver
How do you reset the lms334c?
Hi, continually hold down the zoom in and zoom out buttons while you turn the unit on, keep holding them down until the screen fully loads. Regards Phil.
Jul 07, 2012 | Lowrance Lms332c Lms334c (Lowrance)
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
My GPS just stopped responding to touch.
can you soft or hard re-boot your GPS?
(usually by holding down the down button + menu)
Jul 02, 2009 | GPS
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
The gps does not respond
A friend of mine had a similar problem it was the battery and it was killed took it back to shop and got a new one it was 4 months old.
Jan 08, 2009 | Tomtom GO 700 GPS Receiver
GPS module not responding
check the power connections to the antenna
Aug 23, 2008 | Lowrance LMS-330C GPS Receiver
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
I have a lowrance lms332c and the unit powered off , was able to restart.shortly after powered off again and now has nothing.checked fuse and fuse is ok.
try to hold in the page button and power button at the same time to reboot your unit, But you may or may not lose waypoints,
Jul 11, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance LMS-332C GPS Receiver Logo
47 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
