Question about Nikai DV7000 Camcorder
Can this be charged via adapter to mains it has an av point
I have a tec dv 7000f and want to know if I can use it via the av port with an adaptor instead of two aa batteries
Were is the usb and FireWire port loacated on the Panasonic AG Dvc80?
The DV port is the Firewire (IEEE1394 4-wire) port. The port is on the right hand side (starting in the operator's position) at the top and forward-most point (towards the camera lens) of all the input and output jacks. (It's next to the S-video port and above the composite video and audio ports.) As far as I know, there is no USB port on the AV-DVC80.
The manual is available from Panasonic: http://service.us.panasonic.com/operman/findmanual.aspx?model=AGDVC80 . The direct link is http://service.us.panasonic.com/OPERMANPDF/AGDVC80.PDF . The DV port is shown as point 41 on the diagram on page 14.
I hope this helps.
Aug 09, 2011 | Panasonic AG-DVC80 Mini DV Digital...
I Need an AC Adaptor for this item
Usually MP3 players are charged via the USB cable when connected to a computer.
You can also charge the player with a 5 volt USB mains adapter. These are available in electronics stores and on the Internet.
Sep 20, 2010 | Dell DJ MP3 Player
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
Over loaded via 12volt mains adaptor
at great expense cheaper to buy a new one
Jul 31, 2009 | Tomtom RIDER GPS Devices
Charging on a usb
According to the manual, the HDV188 will not charge via USB, it will only charge using the supplied AC adapter.
Feb 06, 2009 | Jazz DV-179 Digital Camera
Does Gogear charge via the USB plug or only via the 13 amp plug
You should be able to use the play side but I do not think you will be able to charge it.
The transmitter side is taken from the earphone socket.
The power comes from the mains plug via. the Philips lead and is at 5 volts.
I could be telling you wrong as I do not know what adaptor you are looking to purchase.
Dec 06, 2008 | Philips GoGear HDD6330 MP3 Player
Toshiba satellite pro a200 The laptop has stop recharging, i don't know if its the battery or the adapter or the actual laptop with the problem? please help!!!
First do not remove battery and use charger only. Lets start at the beginning first if you are using a UK three point plug check the fuse in the plug. Next some adaptors have a small green light on when connected to the mains. Another way to check the adaptor is, if you no someone with a multi meter (used to check voltages etc) get them to check if there is a reading from the end you plug into the computer should read 19volt. That would check your charging adaptor. Battery well if adaptor is charging then it is almost likely to be your battery.
If you have to replace the battery take it with you when you go for the replacement and ask them to check it in another laptop if they wont do this go elsewhere.
By what you say you have a fault with the adaptor.
Good luck
Sep 04, 2008 | Toshiba Computers & Internet
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Nikai DV7000 Camcorder Logo
13 people viewed this question
Top Nikai Video Cameras Experts
rafnix
rafnix
Tom Chichester
abdul rauf
abdul rauf
Are you a Nikai Video Camera Expert? Answer questions, earn points and help others
