Question about Uniden Cordless Phone
GE cordless phone showing low battery (model 27958GE2-A)
Went to replace battery but test showed battery fully charged, should I replace it anyway?
    Master:
  • Uniden Master
  • 443 Answers
LEO Privacy app has the fast charging screen to help u charge the phone, locks apps and boosts the phone. Very efficient to speed up your phone and keeps snoopers out. LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Feb 24, 2017
    Scholar:
  • 72 Answers
Your phone may have a faulty sensor. If the only notification is that your screen displays low battery, and there is no interruption or disruption of service or quality to the product you can most likely leave it as is. If your phone is still under factory warranty, do not replace the battery, ask for a replacement for a faulty product. I would personally test the lifetime of your phone by leaving it off the charger for a day, and if it lasts the entire day without dying, then it is a problem with your phone's sensor / battery indicator. If the phone dies after a few hours of use or standby, then there is a problem with your battery and your battery tester.
Posted on Jun 15, 2009
Phone is charged but is continuosly losing power. How can batteries run down when it is charged?
Unless the phone is showing any malfunction we cannot confirm unless a drain test is taken in the standby condition of the phone.This must be quite negligible current about few mAmps . If there drains is more check for leak in the battery source to the IC feed, a possible zener shorting or a capacitor leaking.
However if the phone is using up power on talk time , it can be due to drain in a functioning circuit which will be hard to find , but check for unusual heating in any components.
If however the phone works fine then it can be the fault of the battery itself as it could have developed reverse polarity.
Let the battery drain off fully and recharge, if possible a jump charging with an external voltage might sometimes cure this issue.
If not change the battery with the correct current rating.
Sep 26, 2010 | GE 27992GE5 Cordless Phone
My mother-in-law has a uniden phone (with four cordless) and all 4 of the phones show low battery even though the have been sitting in their bases charging. Any thoughts? Thanks in advance
are the charging bases plugged in and turned on? If they are..try replacing batteries on one and see if it works....if so replace all batteries
Jun 15, 2010 | Uniden Cordless Phone
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
Handset 2 show unavailable
hello
there is some battery problem with your phone please service it asap.
Jun 21, 2009 | GE 25841GE3 5.8 GHz Twin Cordless...
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Dec 12, 2008 | GE 25922 Cordless Phone
Low battery problem
Although your batteries are exhibiting a charge memory effect a little early, it doesn't surprise me too much after the phones are in use for two years.
You need to replace the batteries in your cordless phones. These you can find at any Radio Shack. Once yo have installed the new batteries you want to let both batteries go dead from use, keep them off the charger stand for this break in period. If you can do this your phones batteries will last longer.
For more information on rechargeable battery memory effect read this article.
Regards and thanks for using Fixya.
Jun 08, 2008 | GE 21018GE3 Cordless Phone
The display doesn't show the caller ID. It simply shows "no data". PS: I have the caller ID service and the phone is fully charged.
probably your phone have a incompatible call ID system (probably FSK), and your line is DTMF. Needs a standard converter, from DTMF to FSK.
Jan 02, 2008 | GE 27831 Cordless Phone
Uniden Cordless Phone Logo
245 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
