Question about Nokia 5000 Cellular Phone
How do i fix the video quality?
I try to record and the actual video looks rubish
  • jigglyu64 Jun 16, 2009
    ok this phone will suit me till then
    Scholar:
  • 72 Answers
Unfortunately, the vast majority of cellular phones are incapable of producing videos at higher resolutions as digital video cameras or even digital cameras can produce. The reason behind this is that our phones are designed to be compact, and versatile, jack of all trades, master of none. The highest resolution I have seen on a phone was a whopping 240x*xxx* which is 1/5th of a very low end pc's screen resolution and 1/10th or less of a high end pc's resolution. The only possible solution would be to wait 5 years for newer, more powerful hardware, or purchase a digital video camera.
Posted on Jun 15, 2009
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
126 tape only recording 30 min is there a speed setting for recording
Hello - YES the length of time depends more on quality of recording.
The lower the quality the longer the time - or - Better the quality then shorter the time.
Try going into Video settings and try either extreme.
My camera does 10m Pixel video in BEST and 3m Pixels in Normal - so there's a factor of 3 for time.
Ray
Mar 08, 2011 | Cameras
When I capture video from vhs, the result is a lot worse in quality than the original tape. I have tried capturing avi and mpeg, it makes no difference. fixed bitrate at 8000, no difference. Highest...
If you have the option, try capturing your video as MJPEG or DV format without compression, also the resolution must be 720x480 pixels (for NTSC) or 720x576 pixels (for PAL).
It will create a huge file !!! After this I recommend a dvd conversion with deinterlacing for better picture quality.
Hope this helps!
Oct 07, 2010 | DekCell EasyCap USB 20 Video Capture...
Recorded video segment plays back in fast motion. How do i reset
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recordings.
Jan 23, 2009 | Canon PowerShot G9 Digital Camera
Video playing in fast forward with no sound
This should be problem solved for all future recording.
Jan 05, 2009 | Canon PowerShot G9 Digital Camera
My powershot g9 is showing video in fastforward with no sound... how do I fix this?
This should be problem solved for future recordings.
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Recording using A/V in jack - 18 seconds max allowed
Well there could be a couple things- A. there is a problem with the camcorder's software, which will need to be fixed by a LONG phone call with Aiptek Support B. You could be using the wrong component cables for your TV C. You could have the quality set TOO high for your TV's (The PS2 is NOT HD) I recommend DVD quality for this
Hope this helped, sincerely- animation508 (youtube username)
Jul 26, 2008 | Aiptek A-HD 720P Flash Media Camcorder
GoVideo VR4940 has stopped reading recorded discs
try using a dvd lens cleaner to clean lens and then try.
also use a quality brand dvd-r I suggest memorex Brand dvd-r
to record on.
Jan 08, 2008 | GoVideo Go Video DVD/VCR Combo
Nokia 5000 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
