Question about Nikon CoolScan Office Equipment & Supplies
Scanner Not Ready will not load film strip
I am running windows 7 64 bit pro. And my scanner appears to have stopped working. It is recognised as being there but I am told that the scanner is not ready and to insert film. I have tried to do this but nothing happens. It will not load the film. Neither will it scan a slide. I am again told that the scanner is not ready. Everything was fine when I used the scanner the last time. I am using the latest version of vuescan to run the scanner. Any idea?
SOURCE: nikon 8000 film scanner problem
I If you use nikon scan you get a different error warning Update nikon scan and also gdiplus.ddll update from thre nikon web site. It worked for me.
Posted on Jul 27, 2008
  • 110 Answers
SOURCE: Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
old marine
  • 1978 Answers
SOURCE: No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: vertical banding
Well not a complete solution but. . . It will help. 1st Digital Ice will screw up when trying to use it's infrared on Kodakrome so either don't use it or better yet don't use Nikons scanner utils. I use both Silverfast and Vuescan and will never look back yes they both solved this but the real issue is inside but do download a trial of vuescan before you go any further.
Your problem might be a cleaning of the mirror since mounted slides might "curve" in the frame differently and accentuate this issue. Look at this site I clean mine once every 6000 scans which works out to about once or twice a month.
I also recommend (a must do) is run your scanner on its side if you own a sf-210 feeder you already are so look at how this unit attaches on nikon's site or in your manual and do it. This way the guts are on their side (mirror not lying almost flat for all the dust to fall onto it).
Good Luck Morphoto.ca
Posted on Nov 14, 2008
SOURCE: Cannon 4400F Scanner
I had the same problem with about 1 out of every 16 slides when I first got the scanner. The only way I found around it was to rearrange the slides and try again. I started scanning through the ScanGear software instead of Canon Toolbox, and haven't had that problem since. I've scanned about 6,000 slides and negatives so far.
Posted on Apr 06, 2009
I have a tevion film strip scanner suitable for software Windows XP and Vista but my new laptop is Windows 7 and now it won't work. Can I download the software to use the scanner with my new l
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems.
So if you manage to get any driver, just test it. The software that came with your scanner should work. (At least in the XP compatible mode)
The next thing you can try is to download any free ware scanner software. Perhaps you can get a trail version of SilverFast, for your scanner. As soon as you have to pay for the software, think of buying a new scanner, because sometimes a Windows 7 or 8 compatible film scanner is cheaper than the software.
The SilverFast software starts at 59 dollar, (not even sure they have a compatible package for your scanner) My pro version costs already 300. But perhaps you can download a trail version there to see if it works for you. (Perhaps if you remove the software or stop using when you have to pay for it, the driver keeps working??)
Nov 30, 2014 | Office Equipment & Supplies
I have a Coolscan IV with the coolscan 3 Software, and i have a mac book pro. The following message appears: Error "Could not send look up tables to scanner.", Please help me
Try upgrading to v4.02 driver. You may need to download 4.0 first as 4.02 may only upgrade from 4.0. The scanner runs with v4.02 on my Mackbook pro but I can only scan using the slide adapter and the film holder at present. The film adapter will not work but i'm not sure if this is a hardware or software problem.
Apr 06, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Canon Lide 80 Lock Switch error message.
Had the same problem as you but was able to fix it. I basically plugged it in and out while switching the lock switch until it worked. Here is my theory:
The scanner strip got stuck further into the glass instead of tucked in behind the plastic, and i couldn't use the block switch (it was stuck)
When you plug the scanner in it moved a little, i would then be able to lock the switch.
I finally locked it into the position the furthest back, then unplugged it turned the switch to unlock and plugged it in, it worked.
My explanation is a mess but hope it helps you.
May 10, 2010 | Canon CanoScan LiDE 80 Film Flatbed...
Nikon Super Coolscan 5000 ED
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Computer does not recognise scanner
look on your cd (do a windows search function) for files named "...something.MSI". Right click on this file and select either the "INSTALL" or the "RUN" utility. this should force the driver install.
Aug 17, 2007 | Nikon Super Coolscan 5000 ED Film Scanner
55 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
