Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It will not spin a f keeps coming up
Will not spin
Why does belt keep coming off when spinning?
Sadly, this is almost certainly drum bearings worn out and the drum spins off centre, causing the belt to come adrift (I'm guessing your spin cycle has become significantly noisier recently). Worse news I'm afraid, the IWC6125 uses a sealed, non serviceable drum, so this is really an uneconomical repair that will cost around 60%-75% of the cost of the machine when new
Sep 06, 2015 | Indesit IWC6125 Front Load Washing Machine
Helicopter body keeps spinning
add small counter weights on copters plastic body just enough to allow motor to spin without dragging the body and spinning while in flight. check if motor's rotor shaft comes in contact with copter's body, make adjustments on it
Dec 12, 2013 | Toys
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
Lg washing machine is making a very load noise when on spin problem and solutions plaese
when it comes on the spin dosnt make spin and the time doesnt change but the machine keep working but no spin.
Feb 14, 2011 | Washing Machines
Drive belt on hotpoint wm56 keeps coming off when machine goes on fast spin. I have fitted a new belt but it still keeps happening.
Make sure belt is reasonably tight, and it is in the center of the drum pulley, if it still comes off, then I would suspect that the drum bearings are worn, or the drum is running out of alighnment, or the motor bearings are worn, if it is noisy when you spin the drum by hand, then the bearings have definately failed.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WM56 Front Load Washer
Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Aug 21, 2009 | Washing Machines
LOUD BANGING AND SCRATCHING NOISE ON SPIN CYCLE
Urgent stop using it !!!!
The drum suspension is coming to bits , get someone in to look at it before the drum comes through the side of the machine
Jun 16, 2009 | Frigidaire GLTF1670A Front Load Washer
Danby turntable keeps spinning
2 THINGS COME TO MIND--A BAD ELECTRONIC CONTROL PANEL (BEHIND THE KEYBOARD) USUALLY FROM A POWER SURGE,,,,OR A BAD SOOR SWITCH--THIS REPAIR WOULD NEED A TECH--TUNICA
Oct 30, 2008 | Danby DMW119 Microwave Oven
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
10 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
