Question about Timex Ironman Sleek 150 Lap Tap Screen Watch
Changing battery on timex tap
Tap doesn't work after battery change
5 Suggested Answers
SOURCE: How to change battery for Timex Indiglo WR 30M
I second the vice advice...the only thing that worked was to put it in a vice and crank it one more crank then you think is possible. You will hear a little "pop" when it snaps into place. It was the only thing that worked!
Posted on Oct 22, 2008
  • 2501 Answers
SOURCE: Even after changing the battery, the display fades on a Timex.
It sounds like a short circuit somewhere in the watch. A visit to the authorised dealer sound necessary.
To find your nearest dealer go to "casio.com" click on "support" , then from the menu on the left, click on "repair and service" to find your dealer or service center.
Posted on Feb 11, 2010
Testimonial: "Thanks for the feedback. It's out of warranty and I'm not sure it's worth it. "
cmcduncand
  • 714 Answers
SOURCE: HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Posted on Mar 14, 2010
  • 299 Answers
SOURCE: CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Posted on Apr 15, 2010
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
I have timex expedition watch model T49664 with altitude. It works well for last 3 years then battery died. Twice i change CR2430 even once in timex showroom. But the battery dies in 15 days. Plz help
After changing the battery press and hold all the buttons at the same time to reset this will make the watch and battery works properly so that the battery wont drain easily. I hope I have been helped you.
Nov 09, 2014 | Watches
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
Timex ironman 100 lap battery replacement
mcdevito75 here, BEST BET, Look for a small watch repair shop in your area, the tools you"d need, time and the risk in ruinning your watch doesn"t out way the small cost of the shop changing the battery.
May 20, 2010 | Timex Sports Ironman Triathlon 100-Lap...
Apr 09, 2010 | Timex Expedition 84601 Wristwatch
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Jun 01, 2009 | Timex Watches
Timex Helix watch problem
The watch may have more than one battery.
May 18, 2017 | Timex Watches
Changed battery on ironman, watch got wet, now doesn't work
The bad thing about most Timex watches is that once you open them it is very hard to resael them again. The thing is that , the screws are metal, and your trying to tighten them into a plastic back. If you try to tighten them too much you mess up the tap. When the back is first put into the watch there is a very small hole. When they screw them in it's like a wood screw it taps itself in to the back. Once that has been done once it is very hard to keep the same tighteness it started with. Your best bet is to get a watch with a metal screw-on back with a metal casing too. That way you can tourque really hard and make sure the back is tight. If you decide to have the battery changed, make sure they silicon the seal.That's about as much protection agaist water you have with that watch.
Jul 07, 2008 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
Timex Ironman Sleek 150 Lap Tap Screen Watch Logo
37 people viewed this question
Top Timex Exercise & Fitness Experts
Dennis Fitzsimmons
Level 1 Expert
Jimmy Accardi
Are you a Timex Exercise and Fitnes Expert? Answer questions, earn points and help others
