Question about Homelite 2700 Psi Pressure Washer Pump - Fits Most Models
Starting and keeping it running
Trouble starting it and when it does start is will suddenly stop and not start again
1985 Suzuki LT 125 quad runs starts up good just has a ticking gets louder when revved
Hi Ricd, I owned a honda 750 years ago and it would start ticking and get louder and stop suddenly then start ticking and get louder and stop suddenly again and again and so on, It was a worn timing chain......
Apr 15, 2016 | Suzuki Motorcycles
My corolla 2000 suddenly stop , have to wait then start again like nothing happen,
There may be something floating around in the fuel tank that blocks the fuel sock. Stopping allows it to move gain so the engine will start again.
Jul 29, 2014 | 2000 Toyota Corolla
Bike engine stopped
This problem may have many reason but you can try one of the solutions, when suddenly engine stops and kick rod is going smooth without resistance try push and start by directly in 2nd gear or 1st gear and after it starts keep the engine running by giving small revs for a min....
Apr 11, 2014 | 2005 Honda Unicorn
516 Cdi sprinter sudden blue smoking for few minutes and after OK
somthing in the ignition is causing a weak spark--or fuel inject circuit is running to rich----------all causes improper burning---------get a computer diagnostic done
Apr 07, 2012 | Cars & Trucks
Sudden engine stop when running condation with my honda xr 200
my honda xr200 suddenly stop the when runnning & need start again always engine stop when running what is the cause??
Aug 23, 2011 | 2002 Honda XR 200
1999 durango will suddenly stop running while driving. sometimes it will restart run alittle rough and then continues . Other times it will start .but run very rough and stops again, Sometimes I keep foot...
One and only solution you will need to do a OBD2 Scan to retrieve the vehicle computer errors your guess is good as mine what it could be this scan will pin point the exact problem.If you haven't the scan diagnostics tool most garages charge $25-$75.00 for this service
Jan 09, 2011 | 1999 Dodge Durango
While driving, all warning lights on dash suddenly were lit. When I stopped the car, it wouldn't start again and sounded as though the battery was dead.
Probably the alternator died, then used up all the power in your battery to keep the car running.
Have your alternator tested and maybe replaced. The battery needs tested also.
Hope this helps
Sep 13, 2008 | 1995 Volvo 850
Homelite 2700 Psi Pressure Washer Pump - Fits Most Models Logo
32 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
