Question about Nikon CoolScan Office Equipment & Supplies
Scanner not ready
My Nikon CoolScan III[LS30] is not ready I am told, please insert film, but it will not accept the film and when I insert a slide I am still told that it is not ready and to insert film.. Any ideas as to what is wrong. Everything was working fine before.
SOURCE: Nikon Coolscan 8000 ED Film Scanner
Jim try looking into the vuescan software.  It comes highly recommended and is priced very reasonably.
Hope this helps, Rose
Posted on Dec 17, 2007
SOURCE: Nikon Coolscan III LS-30 repairs
I had the same problem. You must remove the cover on the scanner. The reading unit shuld be moving on two metalleaders. It was the oil on them that was dry so i had some oil on and helpt it moving with my finger. Now its working again!
Good luck! Bjarne
Posted on Jul 27, 2008
SOURCE: Glass neg carrier - Nikon Coolscan 9000
Thanks, but yes, I was inserting it correctly. Turns out I had actually purchased 2 defective carriers in a row! I finally got a good one and all is well.
Posted on Oct 20, 2008
  • 3 Answers
SOURCE: vertical banding
Well not a complete solution but. . . It will help. 1st Digital Ice will screw up when trying to use it's infrared on Kodakrome so either don't use it or better yet don't use Nikons scanner utils. I use both Silverfast and Vuescan and will never look back yes they both solved this but the real issue is inside but do download a trial of vuescan before you go any further.
Your problem might be a cleaning of the mirror since mounted slides might "curve" in the frame differently and accentuate this issue. Look at this site I clean mine once every 6000 scans which works out to about once or twice a month.
I also recommend (a must do) is run your scanner on its side if you own a sf-210 feeder you already are so look at how this unit attaches on nikon's site or in your manual and do it. This way the guts are on their side (mirror not lying almost flat for all the dust to fall onto it).
Good Luck Morphoto.ca
Posted on Nov 14, 2008
  • 20 Answers
SOURCE: I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Posted on Dec 16, 2009
Testimonial: "Thanks for prompt and clarifying answer!"
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
Tip
Nikon Coolscan IV ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan IV ED?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan IV ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Coolscan IV ED Film Scanner
Tip
Nikon Coolscan V ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan V ED?
Try this solution:
The slides will fan out nicely, and your Nikon CoolScan V ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon CoolScan V ED Film Scanner
My Nikon CoolScan 4000 is not working properly. All images come with a green shade
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Oct 02, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
I am getting a notice saying hardware error Coolscan V ED
you must perform a p.o.s.t. reset. That is:
1) switch off the scanner
2) swithc off the PC
3) disconnect scanner from PC
5) remove the dia/film adapter
6) switch on tyhe scanner and wait untill it booted
7)insert the film/dia adapter
8) connect scanner and PC
9) switch on the PC
it should work now......
Jul 08, 2010 | Nikon CoolScan V ED Film Scanner
Tip
Nikon Super Coolscan Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 4000?
Try this solution:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon Super Coolscan 5000 ED
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
Rich
Dec 16, 2009 | Nikon Coolscan III Film Scanner
Nikon 8000 film scanner problem
I If you use nikon scan you get a different error warning Update nikon scan and also gdiplus.ddll update from thre nikon web site. It worked for me.
Jul 04, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Good luck! Bjarne
Jun 12, 2008 | Nikon Coolscan III Film Scanner
96 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
michael galang
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
