Question about LG DUCT ASSEMBCONNEC OEM Original Part ADJ36762901
Remove and replace LG DUST ASSEMBLY ADJ36762901
REPLACE ASSEMBLY ADJ36762901
My LG E200 note pad gets hot and is turned off frequently
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 01, 2013 | Audio Players & Recorders
How to replace front wheel bearing on 2003 kia sedona
Disassembly 1. Remove oil seal from front wheel hub. 2. Remove front wheel hub assembly with suitable tool.
bi6c021a.gif 3. Remove retaining ring. note_icon_eng.gif If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
bi6c021b.gif 4. Remove wheel bearing with suitable tool.
bi6c021c.gif note_icon_eng.gif Do not remove dust cover unless necessary. Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ai2a023c.gif note_icon_eng.gif Do not remove wheel hub bolt unless necessary. Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
bi6c021d.gif Assembly 1. Press in new wheel studs. note_icon_eng.gif Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
bi6c022a.gif 2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
bi6c022b.gif 5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
bi6c022c.gif note_icon_eng.gif Use a new oil seal, and apply grease to seal. Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
Jan 12, 2013 | 2003 Kia Sedona
My laptop lg f1 turns too hot and shuts down
Oct 02, 2012 | Computers & Internet
Why is my LG C500 nootbook shuting down by itself?
Sep 05, 2012 | Computers & Internet
My laptop keeps turning off
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 29, 2012 | Computers & Internet
I have an lg lhd65el. It constantly reads the humidity as low and so never turns on. Can I just replace the hemostat?
I think you are referring to a humidistat, not that thing the the doctors use to clamp off a vein to stop the bleeding which they call a hemostat. I also think you are looking for a part number 6877A30013L which LG calls a sensor assembly. Before replacing it, you could try just blowing out the sensor end to remove any accumulated dust, which may solve your problem.
Jul 10, 2011 | LG Goldstar LD65EL Dehumidifier
Hang up after 1 hour
The heat sink may be clogged with dust and this reduces cooling.
Your CPU fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
May 19, 2011 | ASUS P5VDC-MX Motherboard
How do you put in a ball joint in a 2001 sebring convertible
It depends on exactly which ball joint of the 3 per side your changing, but here are the details.
COMPRESSION LOWER ARM & LATERAL LOWER ARM ASSEMBLIES
Removal
1. Loosen compression lower arm ball joint nut. Using steering linkage puller, separate ball joint and
knuckle. Remove nut, bolts and compression lower arm assembly. Remove dust cover.
2. Remove stay. Remove shock absorber lower mounting bolt. Loosen lateral lower arm ball
joint and knuckle nut. Using steering linkage puller, separate ball joint and knuckle. Remove nut, bolt and
lateral lower arm assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for compression lower arm ball joint is 4-22 INCH lbs. (0.5-2.5
N.m) for 2000 models. On 2001 models, breakaway torque is 22-54 INCH lbs. (2.5-6.1 N.m). Ensure
breakaway torque for compression lateral lower arm ball joint is 13 INCH lbs. (1.5 N.m). Check compression
lower arm, lateral lower arm, dust covers, and bushings for damage and wear.
Installation
To install, reverse removal procedure. Use NEW ball joint nuts. Lubricate lip and inside of dust cover with
multipurpose lubricant. Using installer, install dust cover. Check front wheel alignment.
UPPER ARM ASSEMBLY
Removal
Using steering linkage puller, loosen upper arm ball joint and knuckle nut. Remove self-locking nut. Remove upper arm and upper arm shaft assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for upper arm ball joint is 3-13 INCH lbs. (0.3-1.5 N.m).
Replace upper arm assembly when measured value exceeds specification. Check upper arm, dust cover, and
Installation
1. To install, reverse removal procedure. Use NEW self-locking nuts. Lubricate lip and inside of dust cover
with multipurpose lubricant. Using Ball Joint Installer (MB990800), install dust cover.
2. Ensure upper arm shaft assembly is installed at indicated angle. Verify upper arm shaft
assembly installation. Check front wheel alignment.
Once you have the correct arm off and a replacement joint (if available, some are not serviceable and require the arm to be replaced) then you will need a press or a ball joint press to change the joint. Such as
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38335
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46389
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66958
or http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46967
Mar 17, 2010 | 2002 Chrysler Sebring
Need to replace the front wheel bearings on a 2003 Ford F150
I am assuming it is a two wheel drive unit. Remove the wheel. Remove the caliper assembly from the axle and support it so it soes not just hang from the brake line. Pull the dust cap off from the center of the axle end. Remove the cotter key fron the nut. Remove the nut. Gently pull the rotor assembly from the axle spindle. Remove the seal on the inside of the rotor assembly. Lift the inner bearing out of the race. Use a drift pin to remove the race from the hub. Be careful not to score the inside of the hub where the race mounts. Do the same process for the outer bearing. Replace the race and make sure it is fully seated. Grease the new bearings. Replace the inner wheel seal with a new one. Slide the hub back onto the spindle. Place the flat washer on the spindle with the nut and seat the bearings to about 20 pounds torque and back off about 1/8 turn and snug again and replace the kotter key with a new one,. Replace the dust cap back onto the hub and your done.
Sep 16, 2009 | 2003 Ford F150 Regular Cab
LG LE error
Called LG support when I received the LE error on my washer. He had me clean out the drain. Unpluged the machine and then had me press the 'play' button for 10 seconds. After that I was able to use the washing machine - the LE error was cleared
Apr 24, 2008 | LG WM-2277HW Front Load Washer
LG DUCT ASSEMBCONNEC OEM Original Part ADJ36762901 Logo
37 people viewed this question
Computer Repairing
Computer Repairing
