Question about Garden Treasures Egg Fountain 13-MZ03360GB
I would like to add an LED light to the egg fountain. I noticed an LED on another of their fountains at Lowes. Can I purchase the lighted outflow tube from Garden Treasures?
Fountain without light
How to repair the leak in the base of a resin fountain
JB products make a waterproof putty that sets under water called Water Weld. You can get it at Lowes, Home Depot or DoIt Best stores. Cut off a hunk, knead it like dough and seal the hole.
May 21, 2015 | Garden
Just purchased a house with this fountain. The bottom had been coming up And I removed as much as possible. What is the best way to remove the remaining coating? What is the procedure and best material to...
Your fountian is not anything special as far as general waterproofing. I Think the best answer for this problem would be to cement a rubber liner down and then place ceramic tile or marble over that. It may take as much as 3 inches of mud to level it then the marble can be cemented to the mud base.
This will completely waterproof your fountain and also add value to your home. Hope this helps.
Feb 25, 2013 | Garden
I need a replacement pump with lights for lion head fountain
need replacement lights for ion head fountain.
can't replace bulb. Rubber is brittle and broken.
need complete bulb and wire to transformer connection.
where do I order?
Jun 18, 2012 | Garden
How to plug in led lights in a water fountain
never seen one but if you look really hard im sure you will find the plug in it is most likley close to the power inlet these lights run off dc power converted from ac power there is a driver somewhere that has the plug in
May 29, 2012 | Home
I am looking for a replacement pump for a two tier fountian of 120v 60Hz0.12a OK100 submersible with rubber seal 0417969 Fountain purchased at Lowes and they do not sell this particular fountain any longer...
Most pumps like the one you are looking for is easy to find if you cannot find it at Home Depot go on line with the brand and model number plug it in and you will find the right one. Ive installed this kind of pump in three tier fontians before and got it at Home Depot. Make sure after seperating the tier you seal it back up again because it will leak ive used silicone the clear when putting these types of fountians together and it works great i recommend you let it dry over night.
Mar 12, 2010 | Garden
The pump on my weel Willie fountain has broken. Any idea where I would find a new one
Go to lowes or home depot they have fountain and pond pumps in all sorts of sizes
Sep 19, 2009 | Henri Studios Henri Studio Wee Willie's...
Need replacement pump with light
I have the same fountain and same problem. You need a 10 watt 12v halogen bulb. Just wiggle the tube cover off and pull the bulb out. You can buy replacement bulbs at Lowes or 10 for $7.00 on ebay.
Jun 20, 2009 | Garden
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 | Garden
I have the breville Aqua Fountain AF5 and the red light indicator will not turn on. Can you help as to why the red light will not illuminate.
have you changed the filter ? if its still operating, and you have changed the filter, the (LED) might be burned out, if its a new unit, then take it back where you purchased it and have them replace it, if its an older unit and it still works, then you might have to live with no (LED) , hope that helped
Jan 18, 2009 | Heating & Cooling
3-light LED spotlight kit with remote solar panel #555-208
The Spotlight kit should still be under warranty for at least a year through the manufacturer. Check your manual and contact the manufacturer. The problem might be the seal which is allowing water in and therefore it needs to be replaced
Sep 10, 2008 | Spotlight Aquascape Water Proof LED 2-Watt...
Garden Treasures Egg Fountain 13-MZ03360GB Logo
95 people viewed this question
Top Garden Treasures Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Garden Treasures Kitchen Appliances - Other Expert? Answer questions, earn points and help others
