Question about Sony DAV-DZ850KW Theater System
How do recet DAV-DZ850KW - Sony DAV-DZ850KW Theater System
I just need the new password i forgot it
If it is an Android based phone ,them Hold down the Power button and Vol.Up Button .that will show recet options select factory reset by Volume buttins.Press Home to enter.It will recet your phone to defalt but you will loose all s/w and settings.
Oct 28, 2013 | Samsung Cell Phones
Sony DAV-SC5 not playing 5.1 through the optical input from sky/blu ray
The DAV supports Dolby Digital® DTS 5.1 audio. Make sure your blueray movie has 5.1 track and is outputting to the DAV.
Jan 26, 2008 | Sony DAV-SC5 System
Subtitle without using remote
Hell
The anser is NO. You need its origitnal remote control to do this.
Mar 02, 2012 | Sony DAV-DZ850KW Theater System
The rear surround sound speakers are not working.the front ones are and the sub woofer works fine also. everything is connected properly but have no idea what to do to make them work.can you please help
Make sure that the media you are using has the surround sound...eg. if you are listening to the radio then the rear speaskers will not work as the signal is not transmitted in surround...if you put a dvd in that has the dolby digital signal encoded on it then the rears should work....the rears will only work when you have the receiver in the surround mode..make sure the receiver is in the right mode...also, you may have rear speaker volume settings in the setup menu that may need to be set up..go through the manual and see if there is a setting for the rear volume...most home theater sets have this feature and it allows you to set up the system for different size rooms
Jun 11, 2011 | Sony DAV-DZ850KW Theater System
User manual is required
You may please click on this link to download the manual for your Sony Home Theater System
On the page that comes up, rate the product and then click on "download the user guide."
If you require any further assistance, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Jan 29, 2011 | Sony DAV-DZ850KW Theater System
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
DAV DZ-100 problem with reading divx files
This is the correct link for the DAV DZ100 firmware:
http://support.sony-europe.com/hav/downloads/firmware/firmware.aspx?site=odw_it_IT&m=DAV-DZ100&f=FW_DAV2
Try this, it shoul solve the problem!
Bye, Davide (davidecap@alice.it)
Dec 14, 2008 | Sony DAV-DZ100 System
Only get 480p
Hi.
Your friend is wrong you will get same resolution of 1080i whether you use component or Hdmi.
But you will need a high def input to tv in order to get this resolution EG high def cable box or satellite.
http://dysonmanuals.llc.nu/
Mar 24, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony DAV-DZ850KW Theater System Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
