Question about Sony Xplod (P589) Car Subwoofer
Sound buzzing cloth remove for paper part
Sound buzzing rubber get remove
How do i clean the rollers on my printer?
Paper Tray Rollers Step 1 Turn off and unplug your HP printer. Pull out your printer's paper tray and locate the printer rollers on the paper tray. Each roller is gray or black, and they are made of rubber. Remove the rollers from the tray.
On HP inkjet printers, the printer roller is not on the paper tray; it is on the area inside of the printer where the paper tray slides into the unit. Remove the paper tray and sit your HP inkjet printer upright, so the paper tray area is facing upward, and then look for the printer roller.
Step 2
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the paper or internal tray rollers with the cloth. Fold the cloth in half and repeat the cleaning process until the rollers are free of dust and debris.
Step 3
Wipe the rollers with a dry, lint-free cloth to remove any remaining dust or debris. Let the rollers dry completely before sliding the paper tray back into your printer.
Internal Pickup Roller - Laser Printers Only Step 1 Turn off and unplug your HP printer. Open your printer's front door and pull the printer's toner cartridge toward you to remove it from the printer.
Step 2
Locate your printer's internal pickup roller. The roller is gray or black, and it is made of rubber. Lift the roller upward, towards the front of your printer. Pull the roller gently out of the printer and lay it on a clean surface, such as a desk or workbench.
Step 3
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the pickup roller with the cloth. Fold the cloth in half and repeat the cleaning process until the roller is free of dust and debris.
Step 4
Wipe the roller with a dry, lint-free cloth to remove any remaining dust or debris. Let the roller dry completely before snapping the pickup roller back into place inside of your HP printer. Reinstall the toner cartridge and close your printer's door.
Aug 10, 2014 | Dell 1720dn Laser Printer
Paper jam
Dear Friend
the paper jam in the machine is due to the rubber feeders present in the tray bin that pick the paper up and forward them.
so i suggest them to take a cloth and dip it in water and then (just like moisturized cloth) resin it completely that it do not form droplets that gets into the copier.
now switch OFF the machine and try wiping the rubber feeders with the cloth.
you will see a lot of darkness on the rubber feeders.
clean all the runner feeders with it and close the machine.
now your problem will be solved for paper jams.
thankyou
Gagan Gupta
Is that Useful?
Mar 18, 2011 | HP Office Equipment & Supplies
Paper jam
dear ram gupta
thankyou
Gagan Gupta
Mar 16, 2011 | Sharp AR-5316 Advanced Digital Imager...
My printer just refuses to pick up paper. It sounds like it's going to print, then quits & red light comes on. Do I need to clean the rollers???
Yes. Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 04, 2011 | Samsung ML 1710 Laser Printer
MFC has a clicking sound when lifting paper then reads no paper
try to clear paper feed rolers...remove paper tray, look for rubber, clean it whit wet cloth or alcohol or just repleace rollers whit new ones
Dec 14, 2010 | Brother MFC-8860DN Printer
Full of paper, not overloaded, no paper jam, sounds like tpulling paper but doesn't. While looking for on line troubleshooting, started printing my 2 pages that I needed. I tried to print again the two...
Remove the paper from the printer. Open the printer and remove the toner cartridge. Towards the back lower part of the machine is the paper feed tire. It is a gray rubber "wheel" and is on a metal bar that runs from side to side. Take a small cloth and dampen it with some glass cleaner. Clean the tire as best you can. May have to try and rotate it a bit to get to all of it. Then re-install the toner and reload the paper. If this works then great. If not it sounds like you may have a mechanical problem and will need service.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | HP LASERJET P1006 Printer
Not picking up paper
Most new printers and copiers will attempt to feed paper several times before failing and giving a jam condition. It sounds like that is what is happening to your printer.
Your tray rollers may be dirty. Remove the tray and use a clean cloth with mild detergent to clean the rubber rollers. Do not use alcohol this will dry the rollers out. If problem continues replace the tray rollers.
May 18, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Jan 24, 2009 | Samsung CLP 300 Laser Printer
Paper not feeding
This could be caused by rubber that has become clogged with paper fibers or has gotten hard.
If you open the machine and look for the drive mechanism you will likely recognize the part responsible for advancing the paper.
Alcohol can complicate things sometimes as it can dry out the surface that you want to have slightly tacky. I would try lighter fluid (naptha) and a lint-free cloth or paper towel to scrub the surface of the roller to remove built-up fibers and it may also remove some dead rubber that will show up as a black deposit on the cloth.
Parts for these trusty companions has become increasingly scarce since they are passing out of use with time and the advent of disposable printers. Most of those folks using these machines are reluctant to replace them but that may be your only recourse.
Oct 03, 2008 | Casio FR-2650A Calculator
Lexmark scanner/printer x5250
Yup rubber feed rollers can be replaced of even try just cleaning rubber with slightly damp cloth to remove paper dust that causes them to slip and not grip and feed paper as they should
Oct 19, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Sony Xplod (P589) Car Subwoofer Logo
27 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
