Question about Wildgame Innovations Wildgame W8X 8-Megapixel Micro Digital GAME Scouting Camera WITH IR FL
Goes off and only way to turn on is to release the battery door
When set on flextime, it will not work. When i go to check it, she is off and i can not wake her up.
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
Feb 19, 2017 | Cars & Trucks
Why door wont open
There can be many reasons but lets try the most common one first.
No elect power supply to the motor - check circuit breaker supplying elect power to the control box and or DC transformer. Check DC power supply for transformer to control box.
If that is ok adjust the up load turn switch - normally there are two adjusters regulating the open and close forces applied by the motor. If set to sensitive the door will open or close partially or even not at all. Quick check is open the door by releasing the manual lock and lifting the door by hand. Lock the manual lock again, press the door close switch/remote and see if it will close. If it closes the up switch is set to sensitive. Adjust by turning not more than a quarter turn before trying opening the door. If not sure to what side it must be turned turn it fully to the left try - if not working fully to the right and try again. It is however necessary to reduce the setting to a point just enough to open the door with any manual/hand assistance but where it should stop moving if light resistance is encountered such as hand pressure against direction of travel.
Check the remote contol batteries.
Check for some obstacle in the way of the door.
Check if the door is not locked.
Lastly check the micro switch settings on the door motor.
If the problem is not solved manufacturer assistance support.
Jul 19, 2014 | Building Materials
How do I install addition ram in my toshiba satellite laptop L30 134
  • Shut down your Toshiba L30-10S.
  • 2 Unplug the A/C adapter and disconnect all external devices.
  • 3 Turn the L30-10S over and locate the battery pack at the top edge of the computer.
  • 4 Slide the battery release switch to the bottom right of the battery to release it. Set the battery to the side.
  • 5 Locate the RAM compartment door in the center of the computer.
  • 6 Remove the four screws holding the door in place.
  • 7 Lift the RAM compartment door off to reveal the RAM slot beneath.
  • 8 Lift the clips on the ends of RAM slot to release the current module.
  • 9 Slide the module out of the slot at a 30-degree angle and set it to the side.
  • 10 Slide the new module into the slot at a 30-degree angle and press gently down until the latches lock down and hold it securely. Replace the RAM compartment door and battery, then reconnect the AC adapter and external devices.
  • Dec 31, 2010 | Toshiba Computers & Internet
    I have a 92 Lexus ES300. I went to roll down the passenger window, accidentally hit both passenger window buttons at the same time on the driver door switch panel. Both windows rolled down about an inch,...
    Hi
    Thanks for using FixYa. First of all you’ll need to check battery voltage, recharge it if it is low or jump start with another battery charger. Inspect, clean and tight both ends of all battery cables. Also check, clean and tight wiring connections. Check for voltage at relay. If relay has voltage but there is no "click" when key is turned to start, replace relay. Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary. Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Please pry the interior panel and release the inside door locks. If still the issue is not resolved then you’ll need to drill a two inch hole into the latch to access the inside lock link through the interior panel. After removing the panel replaces the latch to resolve the issue. See the picture where to drill---
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Mar 10, 2010 | Lexus ES 300 Cars & Trucks
    2005 Blazer
    Replace the cylinder lock mechanism. The key will have to be turned on to do that. Disconnect the battery first.
    Often there is a tiny hole on the column next to the cylinder. You will need to push a paper clip (or something like that in size) into the hole to release the lock mechanism.
    Dec 28, 2009 | Cars & Trucks
    2005 Ram 2500 quad cab driver side stays locked
    reset this by disconeting battery whilst car is unlocked make sure u take keys out b4 doin this then reconect battery with doors closed this shud rset the door open and release modes problem solved
    Jul 27, 2009 | 2005 Dodge Ram
    Audi 1999 a4 1.8 turbo
    First thing is to disconnect the battery again, wait a minute or two, then hook it back up. Put the key in the ignition, turn it to full electrical power, but don't start it. If you have the hood open, you may hear a humming from the engine - this is the throttle body being aligned by the computer. This will help with driveability. You may need up to a week for the car to fully sort itself out though - it seems to vary widely from car to car.
    Don't forget to reprogram your one-touch windows too. For each one that has one-touch down, hold the button down until the window goes fully down, then release the button and quickly press and release it again. Then hold the button until it goes all the way up, release, press up and release again. This reprograms the one-touch up feature.
    Aug 18, 2008 | 1999 Audi A4
    Change batteries for the lx5 wireless mouse
    1) Press button on base of mouse to release battery door
    2) Remove door and insert 2 x AA batteries
    3) Turn on mouse
    Jul 06, 2008 | Logitech LX5 Cordless Optical Mouse
    Wildgame Innovations Wildgame W8X 8-Megapixel Micro Digital GAME Scouting Camera WITH IR FL Logo
    Top Wildgame Innovations Cameras Experts
    teddyboy
    Steve Mason
    Are you a Wildgame Innovations Camera Expert? Answer questions, earn points and help others
