Question about Sony DAV-DZ850KW Theater System
Master reset your device - Sony DAV-DZ850KW Theater System
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Hope this helps!
Device resets ZTE ZMAX
Nov 01, 2017 | ZTE Cell Phones
Motorola v8 master reset
In order to reset a phone you can look for the steps depending on the model of your device from this website: How to perform Master Reset Master Clear, but you can follow the steps from your specific phone from here: Linux Java Non Touchscreen Master Reset Master Clear
Jun 30, 2014 | Motorola RAZR Cell Phones
How do i reset my pantech
though you had not mentioned your model no yet i give the answer for pantech duo...
IMPORTANT: The device will be set back to factory settings; all data stored on the device will be lost. The device may not be functional for up to 15 minutes after a master reset is performed.
  1. From the standby screen, press Start.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Master Clear.
  5. Enter password, press Done.
    NOTE: Default password is 0000.
  6. To confirm reset, press Yes.
    NOTE: The device will automatically reset and may not function for up to 15 minutes following the master reset.
Alternate Method
  1. Power device off.
  2. Remove SIM and Storage Card (if applicable).
  3. Power the device back on while holding the "S" and "L" keys.
  4. Continue to hold the "S" and "L" keys until the device displays "SIM missing" than release "S" and "L".
  5. Device will master reset.
If device has been locked with a password, and the password has been forgotten follow the below steps:Note: This is for the device password lock only.
  1. Power off the device and remove the SIM card.
  2. Power on the device and press *25327# on the home screen and press OK.
Jun 22, 2014 | Pantech Cell Phones
Securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 5000 Cellular Phone
What is the password of master reset in samsung device?
HI M'praveen kumar so you know the last 4digit of your phone number usually service as a reset code on the non- smart phones for the samsung devices. A smart phone has the master reset in the settings.I 'm keeping it very simple.
Nov 12, 2011 | Cell Phones
How to to know my master reset code?
master reset codes differ from mobile device to device. There is no particular way to determine the exact reset code for a device by going through the device. Master reset codes are usually floated around mobile device experts. Depending on the device i could supply you with the reset code.
Hope this solution has been helpful?
Feb 03, 2011 | Cell Phones
Need master reset code
What is the mobile Brand and Mobile Model?
I got the Master Reset Code at
http://www.superunlockcodes.com/supported-phones/rs12wp7/ and Unlock the Mobile from the Security Lock.....So you Check Your model there and get the Master Reset Code from there!!!!!!!!!!!
Aug 05, 2010 | Cell Phones
What software can reprogram my sony ericsson k580i??
Soft Reset
To soft reset the device, remove and re-insert the battery.
Master Reset
  1. From the standby screen, press Menu.
  3. Scroll to and select Master Reset.
  4. Scroll to and select desired reset:
    • Reset Settings: this option clears the settings only
    • Reset Device: this option resets the entire device
  5. Press Continue.
  6. The device will be restarted, press Continue.
Feb 13, 2010 | Sony Ericsson K800i Cellular Phone
I have a motorolla ming... i dont know the code for the master reset / master clear / its asking for a 6 digit code / i do see only in the manual a 4 digit code
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
  1. Press Start.
  2. Scroll to and select System Tools.
  3. Scroll to and select either Master Reset or Master Clear.
  4. Press Yes when Alert appears.
  5. Enter Master Code (normally 000000).
Feb 19, 2009 | Motorola Mobility RAZR V3
Sony DAV-DZ850KW Theater System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
