Question about Android Apps
How to fix a broken denture temporarily
Denture broke in two. Is there any glue that will fix it temporarily?
My grandmother used too much glue from a repair kit for her denture how can I safely remove the remaining glue
What kind of glue is a big factor. The mouth is very sensitive to things like this. Trim as much of it off as you can with nail clippers. Then sand off what else you can with an emery board and rinse it off to see what it feels like, I would say use fingernail polish remover BUT that could weaken the denture material and also cause other problems.
Jul 18, 2014 | Health & Beauty
Tips for removing glue
Hello, The only way that you can remove the glue is too lightly scrap with knife or take too a dentist that makes and sell dentures and have them fix.
May 29, 2014 | Crafts & Hobbies
How can i fix my dentures ?
if broken and you have all the pieces go to a dental clinic or lab and they will repair it for you. if small parts are missing they will need an impression. if a lare part is missing you will need a new one
May 02, 2014 | Secure Denture Adhesive - Waterproof
My Nikon D300 camera body broke into two, can the two broken parts be joined by a glue
probably...... but could be an ugly fix. epoxy strongest glue....but cna/superglue easier to use
Dec 29, 2009 | Nikon D300 Digital Camera
I drop my 8'' memorex portable dvd player and broke the latch. mod
First on pieces that are broken you will want to rough surfaces with 220 grit sandpaper(if you cannot get paper use a sharp point like a needle to scratch mating surfaces)then if you are afraid of getting glue on anything else except sufaces use a toothpick to apply glue.(you can also coat other surfaces besides mating area carefully with vaseline so glue wont adhere to unwanted surfaces,just dont get on mating surfaces,or glue wont bond)when you coat both mating surfaces with glue then mate together,apply pressure for 5 mins or so then let fully cure,then see if your efforts paid off!!!!! Best of Luck to You !! amtnng :)
Sep 01, 2009 | Memorex MVDP1085 Portable DVD Player
I broke the paper tray on my Ricoh AP 2000; need a replacement
Everything is repairable! Between epoxy, super glue, model glue (works better on the plastics it's designed for) and Duct Tape!?!? Yankee Engineering!!, Come on. :^D
But to answer your question: eBay
Aug 24, 2009 | Ricoh Aficio AP2000 Laser Printer
A key broke off in ignition
TRY SOME SUPERGLUE ON THE REST OF THE KEY AND CAREFULLY PLACE IT ON THE BROKEN SEGMENT, INSIDE THE CYLINDER. IF YOU ARE NOT COMFORTABLE WITH THIS IDEA, THEN TRY TO USE A PIECE OF STRONG TAPE TO EXTRACT THE BROKEN PIECE. IF YOU DO USE THE SUPERGLUE METHOD, THEN OIL THE OUTSIDE OF THE CYLINDER SO THE GLUE WON'T STICK TO IT. PUT A VERY VERY SMALL AMOUNT OF GLUE ON THE KEY AND INSERT IT SO IT ONLY TOUCHES THE KEY. HOPE THIS METHOD WORKS WELL FOR YOU. KEEP ME POSTED. THANK YOU FOR USING FIX-YA. AND THANKS FOR AN HONEST RATING AS WELL. GOOD LUCK.
May 13, 2009 | 1995 Chevrolet Astro
Left rear window stuck down. Hear motor working but doesn't lift the window.
For a Temp fix take it to a local glass tint shop and ask them to wire it up for you so people cant steal it. But the cable broke or the metal clamp that attaches to the bottom of the glass came off (if thats the case get some plumers goup or any other glue that stays flexible when it drys and try glueing it back to the bottom of the glass) I have a 97 Lincoln Presidental TC that happen to both my rear windows and I was able to glue the assimbaly back together for a quick fix, good luck
Jul 24, 2008 | Lincoln LS Cars & Trucks
Smeg Dishwasher button broken
I am trying to fix the same problem. There is a clear plastic frame around the controller that has small plastic arms that the button pushes against. You will find that it has broken off and fallen inside the door. I managed a temporary fix by unscrewing the door panels finding the buts. Remove the clear frame it clips to the controller once you unscrew it from inside the door. I then used super glue to glue it back together. Fix is temporary only lasted 3 weeks and broke again. What you need to do is find a replacement clear frame.
Apr 20, 2008 | Dishwashers
Android Apps Logo
90 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
