Denon dc 30
No functions
HOWTAVOIDAUTOPROTECTION
When the "Protection" indicator comes up the display panel of Denon ... In thermal cases, the circuitry will automatically reset after a few minutes of cool down
DC Protection is not something you can turn off..
Sep 04, 2015 | Denon Audio Players & Recorders
Unable to play pandora on Denon 1912
Check the Denon website. There is a notice for Pandora users. Pandora changed something and Denon products are blocked as of 11/30. They state that they are working on a fix and to check back after 12/6 for the update.
Dec 01, 2012 | Denon AVR1912
How to take protect off a denon receaver
Hello. DC Protection is not something you can turn off. It is a protection system engaged by one of the microprocessors (computers) within your receiver. If any of the amplifiers are bad, and producing DC voltage at the output, the micro will immediately turn the unit off, to lesson further damage to the amplifier or speaker system. There can be other causes of why the unit's DC Protection relay is not engaging, but 90% of the issues, are related to amplifier damage.
Dave
Jun 15, 2012 | Denon DRA-685 Receiver
Which thickness setting should I use when playing my 33 rpm records on my Denon DP 297 fully automatic turntable? 17 or 30?
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Oct 22, 2011 | Denon DP-47F Turntable
Replacement Remote for Denon DC-1
There are a number of Denon remotes listed here:
Denon Remotes
You will have to ask via email if one of these will work with your system-
Dec 18, 2009 | Denon 201SA Audio Shelf Systems
Technical Problem on my Denon AVR 2802
How good are you with electronic repairs...? Do it if only you are confident...
The way you describe you problem it seems more like poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Also, look for any connections that appear to be grasiny or have rings and resolder them too.
Alternatively, suggest that you take it to the Denon service center closest to you.
Best of Luck..
Mar 05, 2009 | Denon AVR-2802
My aplifier Denon UDRA F-10 says "protect"
Blingking Light or Protect usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Denon PMA-100M Amplifier
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
Display goes out after 15-30 seconds...
Press the Dimmer button on the remote. You can cycle through several options for the display brightness or switch it off.
Aug 02, 2008 | Denon AVR-3805 Receiver
26 people viewed this question
 Grubhead
Grubhead
