Question about Husqvarna 23 Hp 48" Deck Yard Tractor
When you turn your mower deck on it comes on and
The mower deck turns on and off while mowing
    Scholar:
  • 157 Answers
Very possibly an open or a short in the electrical circuit that controls the power take-off. Inspect the line connecting the switch that engages the deck all along it's length to see if it's frayed somewhere. If the bare wire is contacting metal, you have a short. Very possibly one end is somewhat loose giving you an open circuit. Take the ends off, clean and reinstall tightly.
Posted on Jun 15, 2009
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 41 Answers
SOURCE: won;t restart..
Check battery,if it's good, check charging system.
Posted on May 08, 2009
  • 4 Answers
SOURCE: deck drive belt comes off when disengaging mower
Need to adjust the tension on the belt.
Posted on May 18, 2009
  • 154 Answers
SOURCE: mowing unlevel mower is brand new
check to see if all the mounts are tight.
Posted on Jun 07, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Why does the deck belt on my Craftsman rider SN 917.276863 come off. I purchesed an undersized belt and it comes off. Purchased a OE belt and it comes off.
be sure you dont have a pulley that is bent or loose. are the belt retainers still in place? the deck bearings are not wore out causing a vibration?
Sep 28, 2016 | Craftsman Garden
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
******* mower cutting deck restart failure
Your switch may be bad or wire come off.
Jun 08, 2013 | Garden
John Deere La175 Battery doesn't charge while mowing. After I mow for an hour or so and turn tractor off, it won't start. When I put the charger on it for a second or two, it turns over and runs....
I had the same problem. My LA 175 mowere deck would not engage and I figured out that the battery was not sending the sufficient 12volts to the mower deck to run the mower. I replaced the battery and that fixed the problem only to reveal the original problem. Within 2 hours of mowing the battery again died. I replaced the voltage regulator and that didnt help. I need suggestions on where to go from here please. Anybody?
Apr 22, 2012 | Garden
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Strange noise from deck of Toro LX426
The engine wont have an impact with the deck because its belt driven. It sure sounds like you have a bad set of spindle bearings,just turning it by hand you wont hear any noise it has to be going fast to hear it. The noise may be coming from your clutch instead of the deck,and it sounds like the deck. Have these things checked out.
Aug 09, 2009 | Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
109 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
