Question about Panasonic Dmr-XW380 Dvd Recorder
What are data channels? - Panasonic Dmr-XW380 Dvd Recorder
Why don't i have the tv guide when up until 7 pm tonight i was getting it...now it just shows data unavailable
try changing channel number of TV to channel you are interested in finding in Electronic Program Guide and wait for 30 seconds for data to get downloaded into EPG
Apr 27, 2018 | The Computers & Internet
Lost data for channels
do an auto scan thru the main menu
Feb 28, 2015 | Cell Phones
My BCT8 Scans great on conventional scan as well as Truck Tracking. Only issue is that it will occasionally stop on a Trunking Frequency, and then won't start again. Not sure if there is a setting or not....
trunking usually incorporates a data frequency. sometimes it is stationary, and sometimes it is random. depending on the radio system in your area, it may be one or both. if it is consistent, just l/o that channel. i seriously doubt it has anything to do with your receiver or the firmware. Trunking is supposed to be hard to track, that's the point. the problem you're encountering is part of the system.
i would try to research the trunking system, if you can find that out, you can narrow down if it's a data channel or not. anything that is broadcast on the data channel (verbally) is also on another channel. just l/o.
Dec 03, 2013 | Uniden Bct8 250 Channel Pre-programmed...
How can i reset the wii i have the chip in and the hack but some of the new games they playfor about 10 min and then stop freez compleetly how can I FORMAT THE WII
Format (Erase) Wii System Memory
This option is used to delete ALL Channels and ALL save data that have been added to the Wii console and will wipe the system memory clean, as it was when purchased new. Please note that if you also have a Wii Shop Account, that data should be deleted first:
To clear information from the Wii Shop Channel, including records of your transactions and rights to download software:
  1. Access the Wii Shop Channel. Select "Settings" from the list of options.
  2. Select "Remove Wii Shop Channel Account." Once completed, all information will be erased.
To delete ALL Channels and save data :
  1. Access the Wii System Settings screen.
  2. Click on the left blue arrow twice to reach the Wii System Settings 3 menu options.
  3. Select "Format Wii System Memory." If Parental Controls are set, enter the PIN.
  4. If you are sure you want to erase the Wii console's system memory, select "Format."
This option will erase your HBC and Neogamma channel too, if you have softmod..
Hopefully this help.
Jan 18, 2010 | Nintendo Wii Console
ACIDENTLY DELATED ALL CHANNEL FROM MY HUMAX, NOW I CAN NOT GET CHANNEL BACK I HAVE ENTERED CORRECT FRQ/SYMBL ETC DETAILS.
1 - The correct sequence for  all channel data input: a.satellite name; b.frequency; c.polarisation; d.data/symbol rate; e.fec. Did you respected that for every single one?
2 - If yes then is the signal strength for each frequency above 80% ?
3 - Did you scanned all satellites after you have loaded the data?
Oct 04, 2009 | Humax Televison & Video
MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
Mar 12, 2009 | Intel Motherboard
I have a x-540 speaker system I brought today. Do I need a sound card to make it work with my pc. I hook it up/no sound.
A stereo computer system with resources to produce and record surround sound channels. Such surround sound channels are played or recorded using an audio card added to the computer system, which audio card controls additional speakers and/or microphones. Software for redirecting instructions from existing stereo application programs and sending these instructions to the existing audio device driver and the additional audio device driver is needed. Resources for processing the digital audio data for either extracting surround sound channels from two channel data provided by the application, or for encoding two sets of two channel audio data recorded by the two audio cards is also needed
Dec 02, 2008 | Logitech X-540 Multimedia Surround Sound...
How to create adsense channels
Creating Channels is very easy, just click on AdSense Setup->Channels then click on "Add new custom channels".
To track the channels in the reports just click on Reports->Advanced Reports and the select the "Channel data" instead of the "Aggregate data" and choose the channel you want.
Sep 15, 2008 | Google AdSense
Data transfer
Basically you need an SD card.
Located in the "Save Data" section of the "Data Management" area of the Wii Settings Save Data are the files created when you save a game's progress (such as high scores, items found, and where the game last saved), as well as data for certain Wii Channels
This data is stored in this section separately from the Wii Channel data, and can be kept, copied, or deleted independently of the Wii Channel it is used for.
Copy the Save Data to an SD Card, then delete it from the Wii
Most Save Data, including Virtual Console or WiiWare save files, can be copied to a compatible SD Card. This gives you the ability to delete that data, then copy it back over from the SD Card to your Wii should you wish to get it back at a later time. (Be sure to copy the data back over to the Wii when you wish to use it again; simply having the SD Card inserted with the data on it will not allow it to be used.)
Jul 09, 2008 | Nintendo Wii Console
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic Dmr-XW380 Dvd Recorder Logo
12 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
