Question about Garden
Engine will not start by pull rope
I have a Yamaha EC5000DVE THE ONLY WAY I CAN GET IT STARTED IS BY USEING STARTING FLUID
    Problem Solver:
  • 17 Answers
Is there any chance that this generator sat with fuel older than sixty days in it?
All gasolines, including non-ethanol, are organic. They will encounter chain phase separation if not treated with a reputable stabilizer. They fuel simply breaks down over time, and it has a very short shelf life.
Fuel that contains ethanol is even worst when untreated. The alcohol in the fuel will draw moisture from the air. Over time, it will accumulate water in the gas storage can, fuel tank, and carburetor, causing corrosion inside carburetor components. This is what I suspect from the symptoms you describe.
This carburetor needs to be disassembled and thoroughly cleaned. The float is probably stuck, and there is a chance that the mixture screw (if equipped) is clogged with corrosion or foreign matter.
If it is possible to remove the mixture screw (sometimes the plastic limiter caps can be easily pried away), be sure to notate the orientation of the screw. Then close the screw until it barely seats, carefully counting the turns. Add this number to the notes, and it can be replaced later to the exact position.
I used a thin piece of wire to clean a badly corroded Honda carburetor once the mixture screw was removed. The wire was used to scrape back and forth through the hole at the end of the seat (it could be seen protruding into the carburetor bore). The screw was lightly scrubbed with a wire brush. The entire carburetor was cleaned with non-flammable brake cleaner, focusing on the float and inlet needle to be sure they moved freely, It started in 4-5 pulls.
Posted on Apr 23, 2014
  • 45 Answers
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Posted on Oct 07, 2008
Opelmanz
  • 62 Answers
SOURCE: Broken Pull String
Yes, it is possible that the spring needs to be pre-tensioned. its also possible that something was put together a little out of alignment, or some part is too tight and its too hard for the spring to wind in the chord. try to reassemble the chainsaw with a couple more turns on the spring and see if that helps.
paul
Posted on Oct 31, 2008
  • 4088 Answers
SOURCE: PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: rope wont pull smooth enough to start engine feels like notch a t
I think someone failed to put oil in the fuel.
Determine if the warranty is active first. Most warranties are effective for 1 to 5 years. If yes return it to where it was purchased or find an authorized repair facility. A written diagnosis by a good independent saw shop ($10-20) might be a good idea at this point. It is difficult to argue repair charges with an authorized repair facility without some documentation in your favor.
1. Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required? If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated without oil mixed with the fuel?
· Remove the spark plug wire and plug.
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and inspect the cylinder, above the exhaust port, through the spark plug hole. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by the independent saw shop should be considered.
4. The final likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Posted on Oct 10, 2009
  • 250 Answers
SOURCE: I havea 16 inch Homelite chain saw , I 've had it
If someone put the wrong sparkplug in the saw it would do the same thing. The plug threads could be too long and when the piston comes up it hits the plug and stopps. If the electrodes on the new plug extend farther out of the sparkplug the piston will come up and hit it and the engine will not turn.
Posted on Mar 15, 2011
Snowmobile ran great all day but seemed to run different on the way home. The next day I went to start it and I couldn't pull the rope. I assumed it was locked up but not sure now.
Problem with starting next day [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-344777.html
Mar 25, 2013 - 13 posts - ‎7 authors
I have a buddy who couldn't start his CF1000 in the mornings and it was like you ... So is the recoil catching and you can't pull the rope? Recoil Rope stretched apart- showing Nylon cords
Mar 2, 2015
Engine seized then not seized??
Feb 23, 2015
2007 Ski-Doo Summit 800 X Motor Quit
Jan 31, 2012
My pull string went bye bye!!
Oct 31, 2008
More results from www.snowest.com
pull start not working - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/...snowmobiles/5470-pull-start-not-workin...
Jan 19, 2005 - When you pull the rope, it should have a little slack followed by a slight... and he couldn't believe that it didnt have a choke. does my sled not ... 1988 yamaha phazer- dies at full throttle
Mar 3, 2010
Need help uprighting snowmobile after tipping over
Dec 28, 2008
More results from www.snowmobileforum.com
Jan 04, 2016 | Garden
How to fix the starting rope on a craftsman weed *******
is the pull rope in front of the engine ???
yes ???
you dont wanna know
Aug 05, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Will not start by pulling rope you have to use starting fluid to get it started
Frank,
Sorry to tell you, it sounds like the compression on your saw might be low. If the saw is a new saw you can look for a bad head/cylinder gasket, or a stuck compression release if it has one. If it is an old saw likely it will need a top end rebuild.
Mar 30, 2014 | Garden
Adjust carburetor
use the chocke. first full closed then half way. when it started let it idle for about 20sec then open it again.
Compression lockup
Remove spark plug. Pull rope several times to blow out cylinder. Spray WD 40 in spark plug hole. Pull rope several times. ensure compression is present. Replace spark plug with new one. Spray starting fluid in cylinder before replacing spark plug. Ensure plug wires snaps on tight. Check oil level, fill with 30w oil if required. All mowers have a low oil start cutoff. Clean or replace air filter.
Sep 10, 2012 | Toro Power Lawn Mower
My lawn mower fires up but idles slow and rough
No adjustments. Automatic governor. Replace spark plug. Ensure blade is sharp and oil is full. 30w oil. Always put Stabile in gas. When you remove spark plug pull rope several times to blowout cylinder. Spray a little WD40 in spark plug hole, then pull rope several times. Spray starting fluid in spark plug hole, replace plug, ensure plug wire snaps on tight. Clean replace air filter.
Aug 09, 2012 | Troy Bilt 5.5hp Self Propelled Mower
I have a honda gx390 13 horse engine I just put a new pull Rope on it and cleaned the carb its been sitting for 3k10 years when I pull the rope slowly it will turn the engine when I give it a good yank...
This is a common problem. The valves need adjusting in the motor. You may eventually get it started and running in this condition but you will probably end up breaking your pull rope a few times in the process. Take it to someone who works on small engines like a mower repair shop.
Apr 01, 2011 | Garden
Oil on sparkplug. cleaned plug but engine dies with oil on plug. gasket problem??
Oil on the plug is an oil problem. it means that either you tipped the mower and oil ran into the cylinder, or you put too much oil in it and it's leaking into the cylinder. Check the engine oil level, empty some if it's over the level it's supposed to be. You'll want to clean the cylinder, and here's how to do it. Get a can of starting fluid. Take the spark plug out, and remove it from the wire, spray a good 5 second shot of fluid in the cylinder, and pull the rope several hard pulls. This will shoot the fluid and oil out the spark plug hole, and the starting fluid will evaporate within a couple of minutes. Spray the firing end of the plug with starting fluid to clean, shake it out, blow on it to get the extra out, and let it dry(should take about a minute.) Pull the rope another round, and then put it back together. It should run fine after that. It'll probably smoke a decent amount at first, but it will go away within a few minutes.
Mar 27, 2010 | Garden
1981 Yamaha xj750rh that is hard to start
your idle/primary(pilot jet) circuit is blocked.Clean the carbs or have them professionally cleaned and put the starting fluid away.
Mar 22, 2009 | 1981 Yamaha XJ 650
Pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
Mar 10, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
