Question about LeapFrog Poppin Play Piano
Leapfrog poppin play piano does not work
Unit does nothing
No sound out of piano?
Contact Yamaha Support via your method of choice linked below:
Contact Us Support Yamaha United States
Apr 15, 2015 | Yamaha P105 88-Key Portable Digital Piano...
Yamaha clavinova cvp55
Try resetting the piano.
Mar 05, 2014 | Music
My piano won't boot up.
Who manufactures your piano? Call them.
Aug 10, 2017 | Casio Celviano AP-620 88-Key Digital Piano...
Piano lights up but will not stay on when i let off of the power button.
there's an on/off switch on the bottom of the unit by the battery compartment. make sure this switch is on, then turn on the power button on the piano.
Jul 12, 2011 | Fisher Price I Can Play Piano System
When I turn the piano on, nothing happens I checked the plug-in but still nothing happened. I just played the piano a couple of days ago and it was fine. Do they have fuses which need to be...
I woulld not even venture a guess as to what brand/model/ etc you have. How do you expect us to have any idea to help you?
I will say that a very common problem is if the unit, whatever type it is, has a power adapter, it is COMMON for the plug to work loose... If your unit has a regular cord, then there are likely fuse(s) inside, but if they blow, there is another problem that must be repaired before fuses are replaced.
Does the unit have any lights or displays that show power is on? If nothing is lit, then VERIFY that the cord is plugged in at both ends... ANOTHER problem is that SOME wall receptacles are switched... intended for floor lamps and if one has the switch off the receptacles is dead...
Again, you haven't given us enough info to really help you...
Nov 10, 2010 | Music
The piano wizard software won't recognize keyboard
you should go to your  utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
Mar 22, 2009 | Wizard Publishing Piano Wizard PREMIER...
Leapfrog Clickstart doesn't switch off and doesn't work
You blew the circuit board by putting to much power into it. Never use more power then suggested for this reason. All adaptors have a volt and an amp rating. Sorry it happend best wishes!
Jan 31, 2009 | LeapFrog ClickStart Educational Software:...
Keyboard doesn't work
are you sure you have the keyboard near enough and pointing towards the computer unit. As it is said that it works wirelessly (which obviously is correct as there are no wires) but this normally means wi-fi which can be moved anywhere however the clickstart works with the very unreliable infa red so the unit needs to be close and pointing towards the keyboard. hope this helps
Nov 29, 2008 | LeapFrog Clickstart My First Computer
LeapFrog Poppin Play Piano Logo
65 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
Ted Maxwell
Andrew Taylor
Andrew Taylor
Morgan T Bradshaw
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
