Question about Whirlpool Washing Machines
Error code u6 - Whirlpool Washing Machines
Is it necessary to replace the compressor if U6 error code appears on the screen ? It is a MR Slim
Not sure what a u6 is but rarely do you need to replace a compressor. Is the compressor shorted to ground? Does the breaker trip when it comes on?
Jun 03, 2016 | Heating & Cooling
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
U6 Error code on dish drawer
It might be helpful if you provide the model number of your dishwasher. It is likely the dishwasher has been set at a water pressure setting different to your mains pressure. If you are in normal water pressure area the selection is HI otherwise LO. Depending on the model the setup information is different.
Jan 26, 2013 | Fisher and Paykel Dishwashers
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
Xerox workcentre 518 gives U6 error whats the issue?
Press 0 button when U6 displayed; If it is U6-0, check control panel connection for proper contact; if U6-1, check paper tray pcb connection to mother pcb.... The paper tray pcb is located at rear side. open back cover and reconnect it.
Jan 05, 2011 | Xerox Office Equipment & Supplies
Mi copiadora sharp AR5125 tiene codigo U6
code Sub code U6 00 Content Desk communication trouble Detail Failed communication with desk Communication line test error occurs when power is turned on or after the exit of a simulation mode. Cause Improper connection or broken wire of connector or harness Desk control PWB defective Control PWB (PCU) defective Malfunction due to noise. Check and remedy Clear the trouble by turning the power supply On/Off. Check communication line connector and harness. U6 01 ~ 03 Content Desk 1, 2 and 3 CS lift-up trouble Detail Desk cassette lift-up trouble (1st - 3rd cassettes). Cause Defective sensor RADF control PWB defective Broken gear Lift-up motor defective Check and remedy Check lift-up sensor detection with SIM4-2
Nov 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Can you plz give me my subsidy code for my motorolay u6 me/35639200234276/on 02 number 07953122172 thanks.
Code:000000 or 123456 or 654321 these are the default subsidy codes.and plz vote me and ratings
May 28, 2009 | Motorola Mobility PEBL U6 Cellular Phone
I Have Xerox 5821 Star Copier and it got U6 error. Help me out
U6 code means that you have a problem with the exposure lamp or exposure lamp circuit working properly.Hold down the 0(zero) key while turning the unit on and punch in the codes 20 start 3 this will enable you to clear the code unless you have a permanent problem where a part has to be replaced
Apr 21, 2009 | Xerox 5100 Copier
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Washing Machines Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
