Question about Samsung RESF3330D Electric Kitchen Range
Electric burner always on high even on low setting
One burner is always on high even though it is on low setting...
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
I have a Beaumark Electric range about 8 years old, The right front burner comes on high as soon as it is turned on, even if I turn it to low it remains on very, very high and burns everything. Why
The burner is not controlled and so it is possible that there is no control on the heating coils.The thermostat settings must be checked as this can be an area where the coils are not controlled for the heat set but goes to the highest level.You will need to remove the unit to check the control action of the controller, check the thermostat and sensor.
Nov 22, 2011 | Kitchen Ranges
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Dual top burner will only heat up on high.It is only the large ring burner GE JBP79
Does it go straight to full heat even though it is on the low setting. If this is the case the hotplate controller is faulty and requires replacement.
Feb 24, 2011 | GE Spectra JBP78 Electric Kitchen Range
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Samsung RESF3330D Electric Kitchen Range Logo
Top Samsung Kitchen Ranges Experts
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
