Question about HP OfficeJet Pro k550 Printer
Printer toolbox where is the printer toolbox
How do you check the status of the toner online?
Using the HP Toolbox
HP Toolbox is a Web application that you can use for the following tasks:
? Check the printer status.
? Configure the printer settings.
? View troubleshooting information.
? View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when it is connected to the network. You must perform a complete software installation in
order to use the HP Toolbox.
Jul 26, 2011 | HP LaserJet 2430 Printer
I cannot check the level of ink in my hp 5610 model printer
You need the HP Toolbox software: Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
How do i find out my ink level on my laptop?
Do you have the HP Printer Toolbox installed?
Follow these steps to check the estimated ink levels from the HP Printer Toolbox. NOTE: If a refilled or remanufactured print cartridge has been installed, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox .
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Printer Toolbox .
    NOTE: The Printer Toolbox can also be opened from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab and then click Service this device .
  2. Click the Estimated Ink Levels tab.
For illustrated directions go to:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01343455&cc=us&lc=en&dlc=en&product=3645100&tmp_track_link=ot_search
You can download updated drivers and utilities here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=3645100#N1089
Dec 15, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do i check ink levels please? HP C6380 printer
  1. Click Start .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
Regards
Riztech
Aug 28, 2010 | HP Photosmart C6380 All-In-One InkJet...
How do I check the ink level on the hp photosmart 8150?
In your HP software "Toolbox" click the "Estimate Ink Level" tab.
To get to the HP "Toolbox"
Click Start > Control Panel > Printers
Right click your printer name, choose "Preferences"
Click the "Services" Tab
Click "Service this Device"
The Toolbox opens
Dec 29, 2009 | HP Photosmart 8150 InkJet Printer
Can't Find HP Printer Toolbox Clean Cartridges Streaks
Opening the HP Toolbox from the Printer Properties
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Properties .
  6. Click the Services tab
  7. Click Open the HP Photosmart Toolbox .
Or if you are not finding it then put in the Disk and Right click explore - setup folder - tool box folder - look for toolbox.msi - right click and install
u will get the options
Oct 17, 2009 | HP PhotoSmart 7150 InkJet Printer
Hi. I have a HP Business Inkjet 1200. What to do to print a testing page? /Christer
Toolbox The Toolbox provides status and maintenance information about the printer. It also provides links to the onscreen user's guide for help in performing basic printing tasks and solving problems.
NOTE: The Toolbox is available for Windows computers only. If the Toolbox was not installed with the other printer software components, you can install it using the installation program on the Starter CD. To monitor a printer on a shared port (for example, \\portname\printername) from a client machine, the Toolbox must be running on the server machine as well as on the client machine. Opening the Toolbox
  1. From the Start menu at your computer, point to Programs .
  2. Point to the printer name, and then click the Toolbox icon.
Toolbox tabs The Toolbox contains tabs that you can use to view product information and change configuration settings. Tabs Contents Printer Status
  • Selected printer The drop-down list displays the currently selected printer.
  • Ink Level Information Shows estimated ink levels for each cartridge.
  • Order Supplies Provides access to a Web site where you can order printing supplies for the printer online.
  • Ink Cartridge Information Shows order numbers and expiration dates for the installed ink cartridges.
  • Preferences Gives you the ability to set advanced Toolbox settings, such as selecting which printer error messages appear, specifying whether you want to be notified by an audio alert when an error occurs, as well as the types of error messages that you want to see. Also, you can turn on myPrintMileage AutoSend, which provides you with a closer forecast of printer usage on the myPrintMileage Web site.
Information
  • Printer Information Provides links to myPrintMileage and shows the printer hardware and printhead health information. You can also use the tab to obtain information about accumulated ink and media use, statistics up to the last 20 jobs, and job tracking.
  • Help Information Provides links to HP Instant Support and HP Customer Support, as well as to the onscreen user's guide for help in performing tasks and troubleshooting. It also provides instructions that guide you through registering the printer onscreen.
Printer Services
  • Align Printheads Guides you through aligning the printheads.
  • Clean Printheads Guides you through cleaning the printheads.
  • Calibrate Color Allows you to calibrate color manually.
  • Print a Demo page Prints a demonstration page. This is used to verify that the printer is connected to the computer correctly and that the printer and printer software are working properly.
  • Advanced Configuration Allows you to set tray lock and select a default tray (if Tray 2 is installed).
Sep 08, 2009 | HP Office Equipment & Supplies
Check ink
Printer Toolbox
Use the printer Toolbox to perform the following tasks:
• Align the print cartridges
• Automatically clean print cartridges
• Print a test page
View estimated ink levels -This is what you would click on.
To open the printer Toolbox
  • 1. Open the Printer Properties dialog box.
  • 2. Click the Features tab, and then click the Printer services button.
The Toolbox is displayed.
I Hope This Helps.
Jan 27, 2009 | HP DeskJet 920c InkJet Printer
Printer wont print
The toolbox software is part of the driver, it wants you to re-run the printer calibration.
Dec 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP deskjet 940c toolbox
Thanks. Without finding Toolbox ( to Clean/Align my printer) I went to Control>Printer>Cick on my printer>Properties>Services>Clean or Align
Interesting that FixYa manages to intervene when I was trying originally to get to HP !!
Mar 01, 2008 | HP DeskJet 940c InkJet Printer
HP OfficeJet Pro k550 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
