Question about Viking 5qt Stand Mixer
Gearbox schematic I am looking for the schematic for the gearbox. does it exist?
Worn out beater gears
Soft plastic gears inside the machine from what I've read around the web, sorry but you'll need a complete new mixer.
I've had one apart to see just how fixable it might be, and it took me about 30 minutes to get the motor and gearbox into a position where they could be looked at. The gearbox had 2 stainless steel clips holding the top cover on and I didn't want to pry at those in case the cover snapped.
Not a lot gained from looking inside it sadly.
Apr 12, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Tip
GEARBOX DRIPPIN OIL KENWOOD CHEF
IF YOUR GEARBOX IS DRIPPING OIL TRY CHANGING THE GREASE INSIDE WITH SUPERLUPE FOODSAFE GREASE.AS YOUR OLD GRESE HAS PROBABLY BROKE DOWN AND LIQUIFIES. ALSO CHANGE OR WASH AND DRY THE FELT COVER UNDER GEARBOX.
**** AT KENWOODCHEFUSEDMIXERSANDSPARES.
07507400101
on Jan 05, 2010 | Food Mixers
Viking 7qt mixer schematic
Not sure if one exists anywhere, but even Viking no longer has them. I am trying to use a Cuisinart schematic for their's to see if it's close.
Jul 17, 2012 | Viking 7qt Stand Mixer
Kenwood Major Model number A707/A
Hello in ebay, you can get a gearbox for A701/A models ..
if you Kenwood is 1962 - 1975 is A701/A
looking the gearbox for this model. or in Billingtonelec.co.uk
Regards
Kenwood Chef Restore
Nov 11, 2008 | Kenwood KM800 Major Classic Stand Mixer
Hobart L800 mixer
Not sure this will help, but here are some things you might want to consider- 1st, get a new appliance technician.
2nd, if the gearbox is not making noise, then you may want to ask a COMPETENT technician to look at your mixer and check that the mixer is wired correctly for the power that you have coming into it. i.e., if you bought the mixer from a kitchen that was using high voltage (say 240v) and you have it wired into a lower voltage, then the shaft will turn, but it will seem very underpowered.
These units have the ability to run off of more than one voltage (120V, 208, 240) and multiple phases. The internal wiring needs to be wired in accordance w/ your supply voltage and phase (there is a schematic on the trans case that you will see when you remove the mixer hood that will show you the correct configuration for your application).
You should find the full wiring schematic on the underneath of the hood when you remove it.
I would also have said competent tech check the input voltage (this can be done at the main input relay) and while he's there, check the output voltage of the same relay to insure that you don't have a partial short. On the side of the relay is a 110v thermal fuse that should be tested too.
If the contactor was shorted, your shaft wouldn't turn and you would see a small green reset on the face of the contactor that would be protruding farther than normal.
Also, on the schematic, you can find the location of the fuses and it would be in your best interest to check those as well.
Hope that helps!
Nov 09, 2008 | Food Mixers
Beaters Misaligned
If this is one of the later-model Sunbeams, the housing has an upper half and a lower half. By removing the upper half, you can see the motor and the gear train. You will have to take out one of the beater gear posts and reinsert it to align properly. I suggest you look at both gear posts and check for worn or broken teeth. In which case, you will need to replace the bad part[s].
Older model Sunbeams have a gearbox housing that mounts onto the front of the motor housing. When you remove the gearbox housing, you will see the gear posts inside. Check for worn or broken teeth and replace as necessary. To insure proper alignment when reattaching the gearbox housing, align the two gears relative to each other then push the gearbox housing back onto the motor housing. The motor spindle will slightly turn both gearposts simutaneously during this process but will keep the proper alignment. You may have to repeat this process a number of times until you get it right.
Feb 02, 2008 | Sunbeam 2350 Heritage Series Mixer
Gearbox input toothed cog
I don´t think you can get a new one, you have to replace the gearbox on the machine.
Dec 02, 2007 | Kenwood KM800 Major Classic Stand Mixer
Hobart d300
http://www.food-equipment.com/parts_Hobart_mixers.htm About halfway down. Hope this helps :)
Aug 01, 2007 | Hobart D300 Stand Mixer
Viking 5qt Stand Mixer Logo
26 people viewed this question
Top Viking Food Mixers Experts
Tom Chichester
Bill Boyd
Are you a Viking Food Mixer Expert? Answer questions, earn points and help others
