Question about Crosley CW6000 Front Load Washer
Washer will not fill with water
All lights but the water temperature are lite up and it will not let you select a temperature it just beeps
I have a Maytag MAV7700 washer. It can fill with hot or cold water but when warm is selected it doesn't appropriately mix them to get a warm temperature even with the automatic temperature co
Hi etjacobsen.
As 'warm' is a mixture of 'hot' and 'cold' water a simple remedy to your problem might be to reduce the flow in the tap supplying the machine.
Good luck.
Nomess
Jan 12, 2015 | Maytag MAV7700 Top Load Washer
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Jan 25, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My smartdrive 058 the water temperature lights up on hot, when I set to warm cold it beeps and does nothing until I press it. Why?
this is what we call a user fault : you may also hear a series of beeps as well usaly idicates hot water is not detected this may occur when warm or hot is selected solution make sure hot water is avalible to machine
Jan 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
My washer won't fill up what is the problem?
Hot and cold tap water valves not turned on.
Bad water inlet valve.
Bad control or temperature selector switch.
The water level sensor is bad.
Or you could have only the cold water hose hooked up and selecting hot wash only. Or you have the hot hose hooked up only and selecting cold wash only. Try selecting a warm wash and see if you get cold or hot water only. If you do, you'll know which is missing.
Jul 28, 2009 | Whirlpool Washing Machines
Washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
May 03, 2009 | Washing Machines
Beeping
the beeping usually is there to tell you something.
It is possible there is not hot water being supplied when you have hot or warm selected
Maybe the water is filling to slow
maybe the filter i clogged
maybe the barrel is out of alignment ( cased but imbalance from previous wash )
is it a top or front loader.
what lights flash when the beeping occurs?
Mar 21, 2009 | Whirlpool GHW9400 Duet Washer
Washer does not fill
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
May 27, 2008 | Washing Machines
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Crosley CW6000 Front Load Washer Logo
16 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
