Question about Cisco Computers & Internet
Cisco 1020 Air-AP-1020 how to reset, and configure as a repeater
SOURCE: reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Posted on Sep 17, 2008
  • 4 Answers
SOURCE: Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Posted on Dec 01, 2008
rahul26485
  • 611 Answers
SOURCE: I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Posted on Mar 06, 2009
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Posted on Apr 23, 2009
  • 79 Answers
SOURCE: IS CISCO LINSYS WAP-610 AN
You cannot use the WAP610N in repeater mode unless you connect it to your router using a cable.
Posted on Dec 17, 2010
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
How to reset password to access AP Cisco configuration.
To reset the password if you have forgotten it, you must reset the whole thing to factory settings, which means you must reconfigure everything. This involves the mode button which is the little button to the right of the ethernet and cable lock slot, this will require a pencil/pen: 1. Disconnect the power to the access point 2.Plug the power cable back in and at the same time hold in the mode button 3.Hold the button for about 3 seconds until the light turns amber 4.Wait for it to reboot and you should be able to reconfigure like it was brand new
Mar 12, 2011 | Cisco AIR-AP1121G-A-K9 802.11g/b Wireless...
Good day, I want to connect three/four Cisco linksys wireless router wirelessly together in a home network such that: 1. Systems working with each AP can comunicate with those with other AP 2. all of...
Ok, what you really want to do is have one router as an access point and the others all set as repeaters.
You'll want to find some WAP54G for the access point/repeaters
The procedure, I cannot explain better than this article does:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4200
it has diagrams and the works on setting those routers into repeater mode.
Post a comment here if you have any issues with that configuration!
NOTE: your configuration should use 2-3 WAP54G with a WRT54G as your main router at the modem.
Feb 22, 2011 | Computers & Internet
IS CISCO LINSYS WAP-610 AN AP REPEATER Range extender?
Dec 14, 2010 | Linksys by Cisco WAP610N Wireless-N Access...
Mar 04, 2009 | 3Com OfficeConnect (3CRWE454G75)...
Nortel phone 2210 not working with Cisco AP 1231
Reason: Previous authentication no longer valid
This suggetss it has the wrong password or the wrong authenticaiton type (WEP vs WPA, for example)
Jan 23, 2009 | Cisco IOS
Cisco Aironet 1200
if u have an cisco acs and windows AD, i'd configure the ap to point to acs and configure acs external db to point to AD. let ur windows dhcp server hand out IPs to your mobile devices.
Feb 18, 2008 | Cisco Computers & Internet
Computers & Internet Logo
144 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
