Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Door lock How can i reset door lock the door won't click shut I ca push lock bit up but wont stay
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
Posted on Nov 02, 2014
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
Door lock problems
Please check on these tips to reset the door lock
click on Door lock
Jan 15, 2013 | Washing Machines
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Hotpoint wm64s indicating door not shut program will not function cus door light flashing...however door iis shut n wont open
You have a mildly confused machine, probably the result of the fact that there is a moment where the door lock can activate, but the sensor that tells if it's shut cant because the door isn't QUITE pushed home hard enough.
First try, just give the door a whack with the heel of your hand in line with where the door catch is. It may be that simple to relocate the door and the sensor properly
Failing that, unplug at the wall and wait 20 minutes. This will, without doubt reset the machine and allow you to open it (While it is still powered off!). Open the door and shut it firmly.... I hesitate to say SLAM the door.... But slam-ish won't hurt, just don't be stupid about it!
All should be OK going forward
Jul 04, 2011 | Hotpoint WMA64 Front Load Washer
Chrysler Aspen 2007 liftgate will not stay up. It does open up electronically but as soon as it reaches the top it shuts immediatly. Can you help me with this?
TAILGATE on 2008 chrysler aspen ...I can push it up and open ,with great effort...but then it won't stay open.....
Mar 22, 2011 | 2008 Chrysler Aspen
Chrysler sebring trunk lock wont latch and stay shut and locked
On the Sebring, there is a small switch on the trunk where it latches. Right in the middle, there is a small button you can push, which will allow the trunk door to shut. It just needs reset. Right where it goes down to lock at.
Mar 03, 2011 | Chrysler Sebring Cars & Trucks
Door won't lock
There is a very small chance the door latch is bad.My opinion with this model is your control board may be out.If your door does click in when you close it then the lock will will activate by the control board.If it wont click shut at all then of course it wont be able to lock.In this case you do have to change the "Door Latch Assembly". Please rate this !!!
Sep 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
Feb 10, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
221 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
