Question about Apple MacBook Air Mac Notebook
Vertical lines no images
    Novelist:
  • 97 Answers
Sounds like your screen went bad.
Close the lid, attach an external monitor, open lid and see if the screen appears on the monitor.
Resetting the PRAM may do the trick also:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
Happy New Year,
Kerry
Posted on Dec 31, 2014
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Red line down middle of television
Try putting a litte pressure on your screen where the red line is,if it goes away then check for a loose pin connection where that line was...
Sep 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
DSC-T1 Digital Camera Display vertical fine lines
Its problem of bad ccd imager is your Sony DSC-T1 camera and this part will be replaced.
Sony will repair this camera for ccd imager problem as per announced scheme.
Please click Sony CCD Imager Support for details.
Apr 01, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
I have a casio exilim ex-z1080 and whenever i take a photo there are vertical lines on the screen, it has only just happened and even when we download the photos they are showing up with vertical lines on...
Are the vertical lines on the images when you view them on screen, or only after you print them on a laser printer of some kind.
If the lines are on screen, your issue is in the device sensor.
If the lines are on printed images, try aligning your print heads (use your printer utilities whenever you replace an ink cartridge), or take the images to a kiosk (Kodak and others have those at verious retail outlets).
DigiChick
Jun 05, 2008 | Cameras
Apple MacBook Air  Mac Notebook Logo
76 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
