Question about JVC Audio Players & Recorders
Jvc ha mr55x
Yanked wire disassembly
How do I set phone call volumne on earbuds with microphone & remote control?
I'm the author of the question - I fixed it by yanking out the earbuds, taking a call and reducing the volumne down from max with the earbuds unplugged. After that, I was able to adjust the phone call volume with the earbuds (JVC HAFX32A Marshmallow Earbuds) plugged in.
Jun 25, 2014 | JVC Audio Players & Recorders
Ha-nc100
Straight up- I do not understand myself nor know how to fix your headphones retractable cord. I however instead of skipping your question chose to give you some informational insight or clues on how to gather your answer.
I have seen that no one has posted to help you as of yet so I figured giving some information on how to find your answer is best rather than to ignore your question. Here are some things that you could type into search engines which will directly take you to either or both reading and video tutorials, which will tell you how to take the headphones apart to fix their cord and or will actually show you the steps to take to fix them.
I am assuming that your question wasn't answered either because no one knew how to fix them or that because they don't know how to fix them they assumed not to make any suggestions since maybe they would had felt bad if they were to tell you to do something in which could ruin the headphones. Here is the following suggestions to go by to fix your head phones: I hope this helps:)
A. Search Engine; GOOGLE.. Search " JVC Ha-nc100 headphones needs fixing to retractable cord".
B. BING SEARCH ENGINE: " WATCH MOVIE ON HOW TO REPAIR JVC HA-NC100 HEADPHONES RETRACTABLE CORD."
C. YOUTUBE; CLICK ON VIDEO AFTER LOGGING IN, TYPE IN SEARCH BOX;
" FIX JVC HA-NC100 HEADPHONES RETRACTABLE CORD"
OR TYPE ;
HOW TO FIX JVC HA-NC100 HEADPHONE RETRACTABLE CORD"
D. YAHOO ; IN SEARCH BOX TYPE:
" MY JVC HA-NC100 HEADPHONES RETRACTABLE CORD NEEDS REPAIR"
OR
FOR YAHOO ANSWERS FROM PEOPLE ON YAHOO YOU MAY TYPE;
" HOW DO I FIX JVC HA-NC100 HEADPHONES RETRACTABLE CORD?"
YOU MAY ALSO TRY ;
" WATCH MOVIE ON HOW TO FIX JVC HEADPHONES".
I HAVE SEPERATED BY COLUMNS AND OR USING 'ENTER' FOR WHAT YOU TYPE IN EACH SEARCH ENGINE BOX IN ORDER TO GET LEAD INTO THE RIGHT DIRECTION ON HOW TO FIX YOUR HEADPHONES.
HOWEVER IF NONE OF THIS WORKS FOR YOU OR IF YOU PREFER FOR MY ASSISTANCE TO GET YOU THE LINKS MYSELF SO THAT ALL YOU WOULD HAVE TO DO IS TO CLICK ON THE BLUE LINKS WHICH WILL DIRECTLY TAKE YOU TO THE SITES THEN PLEASE LET ME KNOW AND I WILL FURTHER HELP YOU.
I THINK THAT THERE IS AN WAY TO COMMUNICATE WITH ME AND OR TO REPLY BACK TO ME. I HOPE THESE SUGGESTIONS HELP. JUST DIDN'T WANT TO LEAVE YOU ALL ON YOUR OWN TRYING TO FIX YOUR ISSUE WITH YOUR HEADPHONES:) HAVE A GOOD DAY/NIGHT.
PEACE SINCERELY,
SIGNATURE 7.:) AKA I AM UNDER THE NAME OF MARIE HAYES.
Dec 25, 2013 | JVC Audio Players & Recorders
Ha-nc100 replacement earpads cushion
CHECK YOUR LOCAL CRAIGSLIST, EBAY, OR AMAZON. THEY SELL HEADPHONES THAT EITHER ARE FOR PARTS OR HAVE BOTH CUSHIONS AND BEING IN WORKING ORDER.
I ALSO SUGGEST FOR YOU TO CHECK:
http://www.jvc.com
OR
SEARCH GOOGLE BY INSERTING THE FOLLOWING WITHIN THE SEARCH BAR: " BUY CHEAP HEADPHONE CUSHION FOR AN; HA NC100 SET OF HEADPHONES"
IN YAHOO SEARCH BAR YOU CAN TYPE:
" DOES ANYONE KNOW WHERE I CAN BY AN HEADPHONE CUSHION FOR JVC HA NC 100 HEADPHONES,
OR
DOES ANYONE GOT A SET OF JVC HA NC100 HEADPHONES FOR SALE THAT MAY BE USED FOR PARTS OR EQUIPPED WITH BOTH CUSHIONS THAT ARE IN PROPER WORKING CONDITION?"
I ALSO SUGGEST TO CHECK www.overstock.com
Dec 02, 2013 | JVC HA-NC100 Consumer Headphones
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
The wire for my headphones jbc stereo headphones HA-TX 300 broke. so can somebody help me how to connect another wire. I'm talkin about the wire that you connect and a mp3 player.
just strip both ends and resolder the connection and cover with tape. If you can't solder, you can just use tape, or wire ties and electrical tape. 1/4 inch of leads on both ends, twist and tape.
Dec 22, 2011 | JVC Audio Players & Recorders
The headphones have stopped working in the left ear. They are jvc ha-v570 headphones. Is there anything i can do?
Andrewjdonne,
This is usually caused by a short in a wire. If you are brave, you can open up the headphones and find the wire that has shorted out and repair it. Usually this happens at the point where the headphones pivot. This may require the use of a soldering gun, or at least some new wire and electrical tape. Nothing you can't find at radioshack. Let me know if you need help opening the casing up to find the bad connection!
~Kudos~
May 03, 2011 | JVC HAV570 Consumer Headphones
My JVC stereo headphone's wire is broken, cant i repair it by myself? please answer quickly because i can only hear from the right side of my headphone, and i love my music!!
If you take off the covering to reveal the speaker you can solder the connection back onto the left side of the headphones and that will fix it.
Mar 01, 2011 | JVC HA-NC250 Headphones
So about a year ago my father bought me a JVC HA-S700 Stereo Headphone set. After i had it for couple of months the insulation on the wire was falling apart on every intersection (the wire from the...
Replace the wires with a set from a junked pair of headphones. You'll have do some light soldering. It's just cheap insulation/wire that caused the problem in the first place.
Apr 09, 2017 | JVC HAS700 Headphones
JVC HA-S700 Cable Problem
You might want to check out my tip on dealing with dodgy plugs/cable on headphones.
Jul 08, 2010 | JVC HAS700 Headphones
51 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
