Question about Scotts Company Scotts Turf Builder Classic Drop Spreader 73730
Drive wheel wont turn
Right side drive wheel wont turn when spreader is loaded
Seed or fertilizer drops down and just sits there, won't turn anymore
Turn the spreader over and inspect the drive gear, by turning the wheels. If the gearbox is enclosed, you will need to open the cover. If the gears do not mesh, then see if you can tighten up any retaining rings or seals. If the gears are stripped, then you probably need to replace the spreader.
Apr 11, 2015 | Garden
My scotts rotory spreader will not spin
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
Hope this helps?.
Apr 19, 2013 | Scotts Company 589384 Scotts 5000 SQFT...
The impeller drive wheel of my classic drop spreader won't turn unless you have a huge load on board. I wash it out every time I use it and dry it thoroughly. I've removed the wheels and tried WD...
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 877-465-5160 at your earliest convenience to check part availability. Hilary @Scotts
Aug 24, 2011 | Scotts Company Scotts Turf Builder Classic...
I have a Scotts dropspreader model 35-3 and I would like to know if there should be cotter pins on both sides of both wheels. My spreader has pins on both sides of one wheel. The other has only one on the...
It's correct as it is. Only one wheel is used to drive the auger. The other wheel is free to rotate without turning the auger. If both wheels were connected to the auger, the spreader would be much harder to turn at the end of the row. You will notice when you make a sharp turn in one direction the auger can remain still and the outer wheel turns easily. If you make a sharp turn in the other direction, then it is harder to turn because the auger is turning. You can make this work to your advantage if you have a large yard. The reason there are unused holes in the free wheel is because it is easier in manufacturing that both wheels are the same and only the assembly is different. Good luck, I hope you found this helpful. Al K
Mar 29, 2011 | Garden
Agri-Fab tow behind 125# Spreader. The gear
Not sure of the assembly but try to loosen the set screw and move the gear, if you assembled this unit the drive wheel may be on the wrong side...
Dec 01, 2009 | Agri-Fab Garden
The front not straight when driving
Its probably bent or broken one of the tie ends on the steering. Ring your nearest suppier they will pick it up and repair it.
Apr 14, 2009 | Agri-Fab Agri Fab Spreader
I have a Scott Rotary Fertilizer Spreader. When I load up the bucket and move the spreader, the fertilizer on the rotor does not spread because rotor does not move
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Mar 09, 2009 | Scotts Company Garden
Scotts Company Scotts Turf Builder Classic Drop Spreader 73730 Logo
Top Scotts Company Garden Experts
john h
lnbn1975
jhnolson
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
