Question about BEHR Premium Plus Ultra Paint. 8 oz. Royal Liqueur Interior/Exterior Paint Sample UL120-1
Dusting dark walls without leaving marks
Can't find anything to dust them without leaving marks.
    Problem Solver:
  • 14 Answers
Have you tried lambswool?
or wetting down the cloths first.
or.......change color! ;)
Good luck
Neil
Posted on Sep 27, 2014
Why does my wall mounted gas reddy heater leave a white mark inside of the unit where the flame is ?
It's dust , mine does it. Heat is constantly rising through there and dust in the air comes with it.
Feb 18, 2015 | Reddy Heating & Cooling
Oce 7051 plain copier has dust or something on one of the rollers - prints have a trail of marks across sheet, repeating every 10 inches from top to bottom of page. Probably need to remove or access...
If the drum has marks on it, you might have to replace it.  Sometimes the fuser rollers can leave marks on them as well.
Check for lines on the drum first.  If they are there, it could need a drum replacement.
Sep 17, 2008 | Office Equipment & Supplies
Why do i have dark smudges on my tv
Usually that is actually dust that has gotten in behind the lcd screen.The dust congregates on top of the tv and eventually falls in through the air grids. Im not to sure how to rectify this without opening the tv up not something I would recommend and can break your warranty.
Jan 06, 2015 | Televison & Video
There is Dark spots on paper when a photocopy is done
Most likely there is something on the glass or something ie: dust underneath the glass that gets in the way of the scanner and the paper(dots) or on the scanner itself(streak). I have heard many times that photocopy machines in cvs/wall greens, any kind of commercial copy places and even libraries deliberately mark on the glass with permanent marker to prevent any kind of copy fraud. You can clean the glass with rubbing alcohol or goof off to remove any stubborn ink on the glass and then use some Windex or something, but if its underneath the glass or on the scanner bar you will need to take some stuff apart clean it and place it back. IF you do that make sure its SUPER clean and you dont leave any finger prints on it
Feb 04, 2014 | Sharp AR-M207 All-In-One Laser Printer
I have the 102mm edu science nova Telescope and was wondering if I take the whole dust cover off the end that points at the sky or just the small dust cap that is on the large dust cap? I am thinking the...
TAKE the whole cap off............ the smaller cap is used for solar viewing WITH the proper solar filter applied to the front of the scope. Never look at the sun without the proper filter.
Mar 30, 2011 | Optics
Copier prints dark on lightest setting
this could be down to several thisngs lift the lid on the top and look at the glass area does the underside look clean or dirty? have a look at the scanner area to see if there is dust ont the mirrors you should see this when you do a test copy press the print button and look at the light unit and the mirrors as they move across the glass if you can see dust or dirt on the mirrors they may require cleaning.. if so turn the machine off take out the screws holding the glass in place lift the glass out carefully.. sometimes they stick down if they havent been cleaned lately so pull up.. take a clean dust cloth slide the scanner unit out for access and clean of the mirrors.. p[ut back together and test if no better open the fornt door and look at the units inside to see if you can take them out..give these a check to see if there are marks on the surfaces of the units.. if the copies are dark usually on a old copier its down to the dust..
Aug 04, 2009 | Office Equipment & Supplies
Video and images too dark
You can try this. Open the cover (Unplug the monitor and leave at least for 30 minutes before doing this). See whether dust is there. If there is dust, get a 1" paint brush and gently remove the dust with the brush. Always sweep the dust away from the unit. If black dust is present around certain cables and around the flyback transformer (that black box covered with aluminium plates), use a soft cloth to wipe them (do not wet the cloth). *Make sure you dont turn those rings on the back of the tube while wiping the the dust. After cleaning the dust, replace the cover, connect it to the PC and check. You will have a brighter picture!
Jun 01, 2009 | LG Studioworks 563N 15" CRT Monitor
My Fresh Air by EcoQuest blows out black like dust/substance. So much so that around the unit and on the wall is turning black. Is this working properly?
The unit is designed to drop particulates out of the air. If you have a heavily polluted area there are more allergens/dust in the air and this might create a 'dust-shower'.
The unit charges particles negatively so the particles bond with positively charged particles. Then the particles drop out of the air or stick to a nearby object. This could leave some black stuff on the wall. You can easily wipe this off, most of this is grime/dust.
Dutch
Apr 24, 2009 | Ecoquest Fresh Air Living Air Purifier
Dark spots on images
Dust on the CMOS sensor.
Sep 14, 2005 | Nikon D70 Digital Camera
BEHR Premium Plus Ultra Paint. 8 oz. Royal Liqueur Interior/Exterior Paint Sample UL120-1 Logo
127 people viewed this question
Top BEHR Premium Plus Ultra Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a BEHR Premium Plus Ultra Tool and Hardware - Other Expert? Answer questions, earn points and help others
