Question about Sony VAIO PCG-8111L Laptop Charger (1300666LMD0011971)
Power supply is working getting power to parts of the mother board, no lights or anything tho. would like to hook up through the battery contact points. need schematics for voltage limits. would that work?
  • 1,087 Answers
Motherboards have 2 power grids the Northbridge and the Southbridge. You can have power to one and not the other. As far as schematics you would need the serial number on the motherboard to find that
Posted on Apr 01, 2015
I need help sony dcr-sr78 shutdown itself i need solution
hi,
I understand that the power supply is not working in your camera if you tested with both battery and charger, then there must be fault in side, must open it, measure the dc power from the primary point to the mother board up to where the power supply goes, on the mother board several fuses lays, if any of it open should replace with the same ampere fuse, voltage regulator SMD could be faulty, if you don't get fault in these all, then check the processor chip.
Dec 16, 2015 | Sony Video Cameras
I recently purchased a new Radeon 7970 graphics card and installed in into my computer which currently is... --AMD Phenom II X4 965 Black -BIOSTAR TA790XE -600 Watt OCZ mod x stream-pro power supply...
Hi David,
Try removing and resetting the CMOS battery on your motherboard. Also, make sure that all connectors from power supply are plugged into the motherboard. There should be power for sys fan, CPU fan, etc.
Thanks,
E.
Sep 20, 2013 | Computers & Internet
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
My inspiron 1420 does not turn on.when i push the power button the light comes on then goes off. can someone tell me where i should check first?
Power supply and or battery. Take the battery out and try to start it with the ac supply only.
If you can find one try another power supply too. Sometimes when your power supply goes bad you just run the battery down till the day it wont restart.
If you have a volt meter you can read the output of the power supply and make sure it is putting out the right voltage.
Oct 14, 2010 | Dell Inspiron 1420 Laptop
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
Laptop will not charge.
bad system board. not much more than that. or the ac adapter may have the green light on but nothing coming out the low voltage side. i am going with that the power module which intergrated into the system board is bad. needs to be replaced.
May 22, 2009 | Dell Latitude 120L Notebook
Dell 8200 won't turn on - power supply is good
Have you put in a CMOS Battery? Hard drive works?Any more information that was not in your first post?
RCF
Sep 06, 2008 | Computers & Internet
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Motherboard
do u have pw switch on right pins power p start with red on that oen go over one to conect the black try both ways never up down on pins tho side to side only ok
Jan 25, 2008 | Intel Desktop Board D845WN Motherboard
No power no light
Could be either one, or it could be the toggle switch.
Start with the easiest first to check. Unplug the power toggle switch from the mainboard and take a screwdriver or something and short out those two pins to see if it starts the pc. if it does, then your pc case switch is just bad.
If that's not the problem, check the power supply next.
Jumper the ATX 20 pin power cable's green wire to any black, just to make sure the power supply is working. The fans in the power supply will turn on along with anything else hooked up.
To jumper the power supply use a section of wire or a bread twisty (with the insulation removed from the ends) and just connect the green wire to any black wire on the 20 / 24 pin power connector. Make sure that the power switch on the back of the power supply is switched on.
If neither of those seem to be the problem, then most likely it is the motherboard or the processor.
Dec 21, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Sony VAIO PCG-8111L Laptop Charger (1300666LMD0011971) Logo
150 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
