Question about LG Washing Machines
Beko 5101w ready wash spinend all illuminated will not let me do anything
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
I have a beko wmb washing machine that stops working as soon as its put on and then the wash and ready lights start flashing... what could be wrong?
Try reading the "troubleshooting" section of the instruction manual. If you don't have the instructions, go to the Beko web site and download them.
Oct 21, 2013 | Beko Washing Machines
BEKO eco care WMA W10, replaced brushes still wont wash or spin,pls help
Hi if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Apr 08, 2013 | Beko Washing Machines
Water wont empty from my machine
Hi if your beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Nov 04, 2012 | Beko WME7247W Washing Machine
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
My 8 month old beko wm6355w has a prob. it fills with water on all progs, counts down to get ready to wash, but doesnt start washing. Ive drained it, cleaned the filter (20p coin and a hair clip) but it...
8 months old- it is still under guarantee then?
Contact the vendor/Beko Service Helpline as soon as you can! It was good to check/clean the filter but do not do anything else which might invalidate the guarantee ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 25, 2011 | Washing Machines
Beko WMA765s washing m/c 'dead'
Hi press and hold the start button for about 5 seconds .see if this works if not you will have a faulty pcb which will need to be replaced hope this helps
regards dan
Mar 19, 2009 | Washing Machines
Beko 520w wasing machine
Hi see the last video on this it will show you test mode or if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 08, 2008 | Washing Machines
Beko wma 1715s
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Jan 05, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
11 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
