Question about Samsung DualView TL220 Digital Camera
Screen won't light up
The camera will take pictures but the but the back LCD will not light up
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
I have a Canon A560 camera. It takes pictures and I can download them to my computer OK. But the LCD screen is black, I don't see any display at all. Pushing the display button does no good.It got...
If your LCD doesn't light up then it's either the backlight or the LCD, you can open up the camera and check the cables before buying any parts. Some LCD screens come with the backlight, some don't; not sure if this one does or not.
IF it was water damage, you probably have corrosion on the main PCB and won't be able to fix it without replacing the board... open it up and check for corrosion!
Hope this helps.
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot A560 Digital Camera
My screen is very dim, my pictures turn out clear and light but i cant see anything on the screen, even stored pictures. I have to put my memory card into a different camera or upload my pictures to see...
This problem is only related with back light in lcd screen and has nothing to do with ccd imager chip as explained by previous expert.
LCD screen is not getting enough voltage to lit back light to show its image thus you get darker image.
I suspect back light circuit section at main board got physical damage due to drop of camera. Visual check by qualified camera tech is needed to fix it.
Aug 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
No picture on the lcd
You need to send the camera in for repair if it's in the warranty period. If it's not still under warranty, then you should get a new camera.
Rob
Mar 15, 2009 | Canon Cameras
My Sony can take pictures, but the LCD screen is frozen with a white picture and a black oval-looking thing in the middle. Any solutions?
You have a faulty LCD screen. The white is the back light and the black oval is the defective screen. This can be repaired.
Mar 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
LCD Screen help
How do you get the camera back to the original settings
May 18, 2008 | Fuji FinePix V10 Digital Camera
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Samsung DualView TL220 Digital Camera Logo
18 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
