Question about Kenwood KID60B12 595 mm Stainless Steel Built-In Dishwasher 15 Place Settings, A Energy Rating
Kid60b12 can't select program
End indicator on but cannot select a program
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Kenwood KID60B12 Dishwasher F2 Fault code
it seems you a blockage.. can you hear the pump running?if you can you will need to unstop it I have done it with just a cloth hanger coming from the front in put side
Jan 01, 2016 | Kenwood KID60B12 595 mm Stainless Steel...
How to adjust height
there are usually 4 feet at the bottom that are adjustable by a couple of centimeters to bring it to right height & level it.
Apr 12, 2015 | Kenwood KID60B12 595 mm Stainless Steel...
How do I prevent the beeper from beeping when the dryer cycle is finished? I did not press the beeper button but I can't seem to program it so it does not beep. Please help. Thank you. My dryer is a T...
In your manual it says if the indicator light is on then the buzzer is on so to turn off the buzzer at the end of your program you would press the button again. Heres is that section from your manual
5. Select the buzzer (if desired)
^ Press the "Buzzer" button to have a
tone beep at the end of the program.
Indicator light:
on = buzzer selected
off = buzzer not selected
To adjust the buzzer volume:
- turn the dryer on
- close the door
- select a program
- if the indicator is lit, press the
"Buzzer" button so the indicator light
goes out.
^ Press and hold the "Buzzer" button
until its indicator is lit and you hear
the desired volume and tone.
also if you need the manual for your machine your can get it directly from this link click here
http://www.retrevo.com/d/ds/progress?doc=508a0566a4fcfb2910e707b71d1fb918&u=1&rk=0.2030122370322724
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks again I await if you have any further reply
Rick
Jun 26, 2011 | Miele T8003 Dryer
About shortcuts of keyboarding
Alt + F File menu options in current program. Alt + E Edit options in current program F1 Universal Help in almost every Windows program. Ctrl + A Select all text. Ctrl + X Cut selected item. Shift + Del Cut selected item. Ctrl + C Copy selected item. Ctrl + Ins Copy selected item Ctrl + V Paste Shift + Ins Paste Home Goes to beginning of current line. Ctrl + Home Goes to beginning of document. End Goes to end of current line. Ctrl + End Goes to end of document. Shift + Home Highlights from current position to beginning of line. Shift + End Highlights from current position to end of line. Ctrl + Left arrow Moves one word to the left at a time. Ctrl + Right arrow Moves one word to the right at a time.
Jun 19, 2011 | Computers & Internet
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
ERROR MESSAGE: "Checksum error."
The Checksum error usually indicates a data transmission issue. This may be due to a loose connection, bad wiring, electrical interference (cross-talk), a physical problem with the device itself, or a conflict caused by another software program. * Make sure that the cable attaching the camera to the computer is secure at both ends. * Close down all of the computer's other applications before attempting to download. 1. Press the CTRL, ALT and DELETE keys simultaneously. This will bring up the Close Program Window. 2. Highlight the program that you want to close and select END TASK. The Close Program window closes only one program at a time, so you will have to repeat these steps for each program that you want to close. NOTE: The SYSTRAY and EXPLORER programs should be allowed to run. Do not select End Task for these programs. You will also want to leave any necessary programs running, such as those controlling a wireless mouse or keyboard.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Kenwood KID60B12 595 mm Stainless Steel Built-In Dishwasher 15 Place Settings, A Energy Rating Logo
Top Kenwood Dishwashers Experts
Owen Barnes
ashburton
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
