Question about Canon PowerShot SD1100 IS Digital Camera
Card locked. Bought new card. Is in the
Card locked. Bought new card. Is in the unlocked position.
Sill saying card locked.
  • Canon Master
  • 4,738 Answers
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
I bought this card at walmart , put it in my camera it says card error card not unlocked how do i fix this
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 14, 2013 | PNY 8GB Micro SD Memory Card
How to unlock a new memory card in my Canon Ixus 750 please. I bought a new memory card a SanDisk 4 GB, loaded it into my camera which is at least 3 years old and it says card locked.
Feb 20, 2013 | Cell Phones
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
Ihave bought A new memory card for my camera but it is saying card protected how do I correct this
You didn't say what make and model camera you have, so I'll assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 22, 2010 | Cameras
Memory card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 18, 2009 | Canon PowerShot A460 Digital Camera
Locked card
If that doesn't work, try another card.
Aug 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
CARD LOCKED
try puting the lock thing onto Lock. it worked for me
Apr 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD1100 IS Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
