Question about Honeywell Heating & Cooling
Unlock radio thermostat CT80
The thermostat is lock with no access to touch screen
Tip
How to unlock the iPod Touch, if you forget the password
<p>The screen lock is available on the iPod Touch, as well as recent models of the iPod and iPod Nano, giving you a 4-digit password to set the screen. This is to prevent others from using your iPod, but it is not a safety device impregnable. If you forget the password, you can quickly and easily unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes. You can then open the iPod and reset the lock to a more memorable password. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer via the USB cable. <br /> <p><br /> <p>2. Wait for iTunes to access and synchronize with your computer. <br /> <p><br /> <p>3. Take your iPod Touch from your computer, clicking on the "Eject" to the input side of the iPod under "Devices" in iTunes. <br /> <p><br /> <p>4. Disconnect the iPod Touch from the USB cable. IPod touch will turn on and will be available. <br /> <p><br /> <p>5. Tap the menu "General" on the iPod Touch. Tap "Passcode Lock and tap either" Turn off access "or" Change. "When you click" Change Password ", you can create a new password. <br />
on Jul 21, 2011 | Computers & Internet
How do I keep an incoming call from going through my lock screen?I'll have my phone in my purse,pocket,etc&I don't even realize that my phone touched something&answered the call without my knowledge.
you will have an option to allow access while locked on your phone. this is usually found in your lock screen options ( settings/my device/lockscreen/allow access while locked ) something like that
May 19, 2015 | Cell Phones
How to unlock it
How to Unlock an Apple iTouch
Although locking your iPod Touch prevents accidental touch commands, the feature also prevents you from accessing your media and applications while the device is locked, according to the Apple site. The lock code is the 4-digit code that was created when the passcode lock was first enabled, and displays a passcode menu prompt on the iPod Touch's screen when the "Home" or "Power" button is pressed and the unlock bar is slid across the screen.
Instructions
1 Push the "Home" button on the iPod Touch's screen, or push the "Power" button on top of the device to show the home screen.
2 Slide your finger on the iPod Touch's unlock bar.
3 Enter the 4-digit passcode using the on-screen keypad to unlock the device. If you cannot remember the passcode, plug the dock-connector cable into the iPod Touch and plug the other end into your computer's USB port. According to Apple, the iPod Touch will automatically unlock after it is connected to your computer.
Jan 07, 2012 | Apple iPod touch
ITS LOCKED AT 75 DEGREES AND DONT KNOW HOW TO UNLOCK
Remove the thermostatfrom its base and replace the batteries. To remove the thermostat, grasp it atthe edges and pull toward you. The batteries are on the back of the thermostathousing. If this doesn't unlock the touch screen, continue to the next step. Check that the furnace'sfuse is not blown or that the circuit breaker is not tripped. Replace a blownfuse or reset a tripped circuit breaker, and try the thermostat again. Press the"Screen" button on the touch screen, then wait for 30 seconds andpress "Done." In many cases, this will unlock the screen and thethermostat will be ready for normal use. Wait five minutes for thecompressor timer to reset if "Wait" is displayed on the screen. Thenoperate the system normally.
Read more: How do I Unlock the Digital Display on a HoneywellRTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KUJvAB9
Jan 04, 2011 | Heating & Cooling
My thermostat is not working. It might be locked. It's blinking with all of the information it holds flashing on the screen. The part number is: tstatccnhp01-c My heat is no longer working. Can you...
Instructions
  1. 1 Unlock a partially locked screen by pressing any locked key, which will bring up the "Screen Locked" message. Next press an unlocked key, which will likely be the temperature up and down arrow keys. This will unlock the screen.
  2. 2 Press the "System" key from the home screen. Five blank touch keys, flanked by the "Done" and "Cancel" keys, will appear. Hold down the middle key for about five seconds. The Advanced Settings menu should come up.
  3. 3 Change the User Setup Number, found in the bottom left of the screen, by pressing the middle arrow keys up or down. Set the number to "0670," the universal unlock code.
  4. 4 Turn to the arrow keys on the right side of the screen. Press the keys up or down to change your options. Selecting the number "0" will unlock the screen, while choosing "1" will partially lock it. You can fully lock your screen again by selecting.
Read more: How to Unlock the Screen on a Honeywell Thermostat ' eHow.com http://www.ehow.com/how_7667347_unlock-screen-honeywell-thermostat.html#ixzz19ktDWSq8
Jan 01, 2011 | Heating & Cooling
Honeywell th8110u1003 touch screen frozen working but cant adjust at all
It sounds "locked". Refer to the installation/setup manual that came with the tstat for information on how to lock and unlock the thermostat.
Apr 06, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Commercial PRO TB7220U Touchscreen Programmable Thermostat wont come off screen lock and we wanna turn on air conditioning... how do you shut off screen lock?
That one is fun. Touch the system cycle button. then touch the two spaces on both sides of the center button at the bottom hold them down at the same time. After 5-10 seconds the screen should flash and show numbers int the center of the screen touch the screen til the numbers 670 appear. then change the numbers beside it to 0. then click done. now you should be able to adjust temperature as needed
Apr 13, 2008 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
