Question about Salton Perfect Touch Electric Blades Grinder
The blade is bent and week. the center holder for the blade is also broken and fractured. Can this be replaced and for how much.
The blade bent on both sides. Center attachhment holding down blade is destroyed.
Wobbly blade
If you have a wobbly fan you want to check ALL screws including hanging brachet. If you have a bent blade holder or warped blades they would need to be replaced.
Oct 15, 2015 | Dryers
My fan is swaying and is very wobbly. I'm trying to figure out how to fix it
First, start at the top and make sure the hanging bracket is tight against the electrical box. If your fan has a downrod, make sure the set screw is tight. Next, check the blade holder and make sure they're tight. Then check the blades screws. If one of the blade holders are bent, even a little, they would need to be replaced. And lastly, check the blades to see if they are warped. If so, they would need to be replaced.
May 14, 2015 | Windchaser WCUFLTI Tower Fan
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
My emachine monitor keep saying no singale
May be a bad pin (bent over or missing) on your monitor cable to the video jack on your computer. If a bent pin, you can straighten it with small needle nose pliers; VERY SLOWLY--fast moves can fracture the pin and break it. If a pin is missing (broken off), the connector must be replaced. If connector looks good, and is not a molded, but a soldered type, a broken solder joint can be repaired, If it is a molded cable, the entire cable must be replaced.
I focused on the cable because this is the most common cause of "no signal", and further troubleshooting would be 'involved', to say the least.
Mar 01, 2013 | Computers & Internet
Metabo die grinder vibrates realy hard when turned up. Is there a repair, or should i toss it?
Two things can cause this,the blade isn't centered or the shaft is bent from a fall.Take the blade off and make sure the center hole is over the shoulders on arbor nuts. To check for a bent shaft take off the blade and tighten the arbor nuts and bring it up to speed.You can email them http://www.metabo.com/E-Mail-Center.2032.0.html The Metabo 3-year warranty
Our power tools have a particularly long service life. Since repairs are so rarely required, Metabo has developed an additional warranty for you - the XXL-warranty.
If you register, the normal warranty is extended to 3 years. Prerequisite is the sales receipt together with the XXL warranty certificate that you can generate after registering your machines.
You can register within the first 4 weeks after the purchase.Thank you for choosing fixYa
Nov 29, 2011 | Metabo GE700 Grinder
Husqvana LTH 2038 model, blade is bent so bought new ones, when i tried to put on the new ones the right hand side one hits the deck. What could it be (checked the blades they are the right ones)
Probably bent jack shaft or bearing. Or the deck bent, where the bearing is mounted. It is possible but probably just jackshaft. Or when you put the blade on it got hung on the part that go's in the center of blade and made the blade sit crooked. Thats what I do.
Jan 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Uneven cutting with the center blade
Bent or dull blade.
Have it checked, or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 01, 2009 | Toro Lawn Mower With Toro Power Tools
Center cutting blades are all bent up and broken/
Probably have to go to the manufacturer. It may NOT be economical to repair the unit.
Sep 15, 2009 | Office Equipment & Supplies
REPLACE BLADE IN MOD #172.171800 8.0 A, CRAFTSMAN, RECIIP SAW
If you see a set screw where the blade goes, loosen it a few turns. Then run the saw, it should spit out the broken blade. If it has a manual release for the blade, press the release while tapping the blade holder.
Apr 29, 2009 | Craftsman 8.0 amp Reciprocating Saw
Broken part for Technique food processor
PLease check ebay seller churkey123 if these are the same processors. WIll send replacment parts for blade holder for postage!
Dec 09, 2008 | Food Processors
Salton Perfect Touch Electric Blades Grinder Logo
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Anthony Turner
Level 1 Expert
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
