Question about Longboard 1-3 Board Soft Racks Surfboard Bag Kayak Car
When it rains straps get wet inside the car
Soft surfboard rack straps inside the car get wet and drip
Driver side wet when rains
The air intakes at the base of the windshield are supposed to direct rain water to drainage ducts in the front door pillars. The ducts can become clogged with leaves and debris. This may be the source of water on the carpet.
Apr 26, 2016 | Hyundai 2007 Sonata GLS
Iam getting rain in my 2003 HSE why.
And where exactly is this rain coming from? The sun roof? The door seals? Seeping in down in the footwells (soggy carpet)?
Sometimes "rain" can be mistaken for A/C condensate that is not draining due to a plugged condensate drain. If your A/C is running and it's hot and humid out then you should see some water drips on the ground underneath the front area of the vehicle. Let it sit in one location for a few minutes after you come in from driving it. Let it sit for a few minutes with the engine and A/C running. Move the vehicle and look for the telltale wet spots from the condensate drain. If you don't see a wet spot then chances are the drain is plugged. The condensate will back up and drain inside the car ...typically in the passenger footwell and making the carpet wet.
Jun 24, 2014 | 2004 Land Rover Range Rover
Will my boards be safe in a soft rack when I drive on the high way?
The soft racks aren't really designed for long trips at high speeds. If you're going to be driving on the highway with your boards you might want to look into getting a hard rack.
Oct 27, 2013 | Water Sport
Are hard roof racks better than soft roof racks?
Soft roof racks are good if you don't carry your board often because they are easy to put on and take off, but since they aren't totally secured you run the risk of scratching up the roof of your car, while the hard racks are more permanent by attaching to the cars roof crossbars.
Wet patch on rear passenger seat nearside but interior of roof dry mini convertable2004
This might be from condensation dripping from the roof inside the car - then drying up - like a rain cloud inside the car
Mar 11, 2010 | 2004 Mini Cooper
Floor get wet when it rains on passengar side carvan
check the weather stripping on your door and the seal on the windshield also make sure the windows are 100% all the way up. Good way to find out where it's coming from is goto an automatic car wash and while it's washing your car watch for water to drip.. if your not sure if you will see it if it comes through the windshield you can always hold up some construction paper (obviouisly you can cover more ground with that than notebook paper) and see where it gets wet :-) if you dont find it there i'd check the floor boards and see if/where the carpet starts to get wet first under the dashboard
Nov 26, 2009 | 1998 Dodge Caravan
Can you confirm how the straps are correctly to be used to hold the surfboard in place?
Place pads around your cross bars, thread straps over the board and under the bar on the far side and then over the board with the buckle end on top of the near side of the board. Then wrap the other end under the bar and 1 time around on the near side, thread through the buckle and pull tight....repeat.
Sep 28, 2009 | Da Kine Car Rack Pad Set Surfboard Bag...
Longboard 1-3 Board Soft Racks Surfboard  Bag Kayak Car Logo
62 people viewed this question
Top Longboard Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Longboard Boating Expert? Answer questions, earn points and help others
