Question about Garmin nuvi 255W GPS Receiver
Garmin nuvi 780 GPS touch screen not working
Dimple under the screen indents when you touch, but not where you touch. not responsive
  • 638 Answers
SOURCE: Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Posted on Jan 08, 2009
  • 23 Answers
SOURCE: Touch screen not working on garmin nuvi 670
Has this been solved? Hold power switch to right for about 30 seconds then follow on screen help to recalibrate screens
Posted on Jun 12, 2009
  • 7 Answers
SOURCE: Garmin Nuvi 255w freezes
mine would constantly cycle in the reboot. I had to clear the stored data by pressng and holding the lower right side of the screen and turning on the gps. once it boots up, it will ask if you want to clear the data memory (will not clear the actual maps). say yes, when it reboots, you will have to redo your personal settings as if it was new out of the box.
Posted on Mar 31, 2010
SOURCE: garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Posted on May 10, 2010
riceski
  • 1851 Answers
SOURCE: nuviĀ® 255W Car GPS Receiver: The screen of my Garmin nuvi 255w GPS is white and...
Press and hold the lower right corner - then see second picture
Posted on May 21, 2010
Touch screen is defective. seems to have dimple under the face and when you push is indents, but not responsive
If there is physical damage to the touchscreen, then it can become unresponsive and will need to be replaced. The touchscreen is bonded to the glass (they are one piece), so both the touchscreen & glass will need to be replaced, even though the glass may not be cracked. Please see this link for more information and how to have the touchscreen replaced for you.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 30, 2014 | Garmin nuvi 780 GPS
The garmin turn on them the light turn off and the touch screen does not function. the version is the nuvi 780
Possible bad battery---are you charging with the lighter plug in the vehicle or what? That plug it uses for the lighter will have a fuse inside it in most cases.........
Nov 08, 2012 | Garmin nuvi 780 GPS
How can i reset my garmin nuvi 780
The following solution is available on Fixya:
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings.
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mod.
Sep 02, 2011 | Garmin nuvi 780 GPS
My garmin nuvi 750's touch screen doesn't respond when touched. The unit powers on ok, but I can't use it...
There may be something wrong with the screen. I would suggest either buying a new screen and replacing it yourself or having a professional install a new screen.
DIY
http://cgi.ebay.com/GARMIN-NUVI-Nuvi-750-780-LCD-Screen-Display-Digitizer-/320549764373?pt=PDA_Accessories&hash=item4aa2413d15
Professional
http://www.fixmygarmin.com/garminrepair_details.php?pid=678
It almost makes more sense to simply purchase a new model.
Mar 09, 2011 | Garmin nuvi 750 GPS Receiver
Unable to unlock Nuvi 780 screen. The slideing button on the top left dosen't work, it lost the grip and just move on either direction with out any action. Please help
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then you have to calibrate the screen. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Dec 24, 2010 | Garmin nuvi 780 GPS
How to reset pin on nuvi 780 if you forgot the pin number
Hello :
1:Turn the Nuvi on.
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mod.
Please rate !
Apr 14, 2010 | Garmin nuvi 780 GPS
Unlocking my 780 garmin
Hello. Carefully lift the frame around the screen using your fingernail. Under that frame is the reset button. Push it and you are good to go. Regards, Joe
Dec 22, 2009 | Garmin nuvi 780 GPS
Touch screen not responsive. LCD screen OK.
Try to calibrate the touch screen .
If not send it to a repair centre they will fix the touch screen for you.
Try here www.satnavrepairservice.com
Regards
Jul 18, 2009 | Garmin Nuvi 680 GPS Receiver
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Feb 20, 2009 | Garmin nuvi 780 GPS
Screen is black
Most likely you will need to do a re-set. Just slide the power switch to the left for 8 seconds. It should then re-boot. It this doesn't work, you've got more serious problems.
Jan 01, 2009 | Garmin nuvi 780 GPS
Garmin nuvi 255W GPS Receiver Logo
94 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
