Question about Proform 110R Exercise Bike
Resistence not working
4 Suggested Answers
SOURCE: Lost the power supply for our exercise bike -
try powersupplyforexercise.com
Posted on Jan 02, 2011
  • 457 Answers
SOURCE: proform gr 80 recumbent exercise bike cant get the
The GR80 uses for type D batteries. The battery compartment is on the bottom of the console, look for the D-shaped battery door, press the tab located towards the front side of the console and open the door. Careful, the batteries may fall down if you open the door - type Ds are heavy enough to be felt when they fall on your feet.
Posted on Jan 16, 2011
ercupa190
  • 12223 Answers
SOURCE: Type your problem for a solution...where do you
Dear Sir:
Hello I hope everything is o.k
I will try to help you, please to the next web page, is from Proform.
Explore www.iFit.com for details.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 03, 2011
Ni-Trac VA-500 exercise bike ( which I bought 2nd hand, in good condition) resistance has stopped working
If it was clicking the resistance motor is stuffed replace it they are quite cheap and easy done, but also make sure the flywheel is tight as they loosen over time as well. You'll need the crank tool, I made one from a m20 metric fine thread and drilled and tapped but you could probably get one from a local cycle shop. Easy job, worth doing these bikes are real nice ??
Jan 30, 2015 | Exercise & Fitness
I have a Proform Hybrid elyptical/incumbent bike and the resistance levels no longer work .How do I repair this?
Hi There ,
There might be a problem with the resistance motor.
Ring Icon Fitness, they are the distributor for this brand world wide.
Sep 10, 2014 | Proform Hybrid Trainer Elliptical And...
Resistance settings not working on fitnex r70 magnetic resistance exercise bike
If this is a new bike that may be the way it is. If it worked differently in the past, you may be looking at a busted tension motor or faulty brake.
Jan 03, 2014 | Champion Fitnex R70 Recumbent Exercise...
Resistance stops after a few seconds
Always check the sensor alignment first. If its properly aligned, check the sensor magnet. If thats ok, replace sensor
Nov 20, 2013 | Proform 315 Csx Recumbent Bike
What are the different resistances on exercise bikes?
There are three main types of resistances, the fan resistance used to provide resistance with air they push as you pedal. The second type is the belt resistance which uses a belt that runs through a brake providing resistance for the exercise bikes. The third type is the magnetic exercise bike which provides resistance which can easily be adjusted while riding the bike.
Aug 09, 2012 | Exercise & Fitness
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Magnetic resistance not working on proform gl105 exercise bike. belt is intact
Just oil the area of magnetic resistance and if the problem continues then contact nearer repairer.
May 15, 2010 | Cycling
No change in resistance
IF you have the one i have, there is a knob with two connected arrows and a plus and minus sign. turn toward the plus, more resistance, turn toward the minus, less resistance.
Feb 04, 2010 | Tunturi E30 Ergonomic Exercise Bike
Proform 110R Exercise Bike Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
