Question about Canon PIXMA iP3500 Printer
Resume printing does not resume printing
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Mp220 absorber full check printer 5b00
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the
Destination settings procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal)
9 times Green CD-R print position correction
(vertical)
10 times
or more
Return to the menu selection
Feb 05, 2014 | Canon PIXMA iP3300 InkJet Photo Printer
Canon IP 3000 - ink absorber full
<Service mode operation procedures>
is selectable.)
Power button.)
PRINT.
Jul 02, 2010 | Canon PIXMA iP1300 Printer
How do i fix "Waste ink full" to resume printing
Hello there
Canon Pixma iP4200, Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction. :
Look at the table below:
· 1 led- Orange – Service test print 1 times – Orange – Service test print
· 2 led – Green – EEPROM information print 2 times – Green – EEPROM information print
· 3 led – Orange – EEPROM initialization 3 times – Orange – EEPROM initialization
· 4 led – Green – Waste ink counter setting 4 time – Green – Waste ink counter setting
· 5 led – Orange – Destination setting (Press Power > Press Resume 3x) 5 times – Orange – Destination setting (Press Power> Press Resume 3x)
· 6 led – Green – Print head deep cleaning 6 times – Green – Print head deep cleaning
· 11-13 led – Orange, Green, Orange – Return to menu selection
· 14 led – Green – Left margin correction 14 times – Green – Left margin correction
  1. Turn off the printer POWER button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Cannot find resume button on HP 7210
the resume button is on the control panel . Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints. you may have to hit enter to get to see resume after you have cleared the jam
Nov 11, 2009 | HP Officejet 7210 All-In-One InkJet...
Canon 19900 printing fine then refuses to print showing error 300
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Sep 16, 2009 | Canon i9900 InkJet Photo Printer
My Canon i850 flashes in a continuous cycle of one green followed by 7 yellow blinks when switched on, and does not print. What is the problem and how can it be solved?
try the following
1. Start with printer OFF
2. Hold down RESUME and then press and hold down POWER Button.
3. Release the RESUME but continue to hold down the power button
4. Press the RESUME twice, then release POWER button.
Now you have put the printer in Service Mode so it will accept Service commands. Here is the list of Service commands;
A. Press the Resume button once = Print Service test print
B. Press the Resume button twice = Print EEprom data sheet
C. Press the Resume button Three = Initialize the EEprom
D. Press the Resume button Four = Clean Waste INk Counter
E. Press the Resume button Five = Change Destination settings
F. Press the Resume button Six = Head Refreshing (Cleaning)
G. Press the Resume buttom Seven, Eight, Nine, = Not used
H. Press the Resume button Ten = Return to selection Menu
Jul 28, 2009 | Canon i850 InkJet Photo Printer
I9900 printer has error 5B00 & won't print
You may need to change the ink absorbers. But try resetting the printer:
Canon I series service mode
D. Press the Resume button Four = Clear Waste INk Counter
To EXECUTE anyone of the above commands you "MUST Press the Power button one time. Then the function will be executed. After that function has been executed the printer will REMAIN in Service Mode,.. waiting for another command. You can only execute one command at a time. If you are through with all the commands you want to do, just press the power buttom one more time and it will turn the printer off and you will be out of Service Mode. One more note. When you get the printer into Service MOde and it is ready to accept a command, the green light will be on and steady. As you issue a command by pressing the resume button, it will alternate the color from green to orange with each press of the resume button. Remember, if you issue either one of the commands to force a print make sure you have paper installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My iP8500
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights
in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
4) When The LED lights in green, press the Resume/Cancel button the specified number of time(s) according To the function listed in the table below. (Each time
the Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation
completes, the printer returns To the menu selection mode automatically.)
<Destination settings procedures>
in the destination settings mode, press the Resume/Cancel button the specified number of time(s) according to the destination listed in the table below, and press
the Power button.
Note: After setting the destination, confirm the model name in service test print or EEPROM information print.
[See 3.4. Verification Items, (1) Service test print, or (2) EEPROM information print.]
To the top
Time(s)
LED
Function
Remarks
0 times
Green
Power off
When the print head is not installed, the carriage returns and
1 time
Orange
Service test print
See 3-4. Verification Items, (1) Service test print.
2 times
Green
See 3-4. Verification Items, (2) EEPROM information print.
3 times
Orange
4 times
Green
5 times
Orange
Proceed To the step 5), and follow the destination settings
procedures.
Destination
1 time
Orange
Japan: iP8600
2 times
Green
Other than Japan, non-support of CD-R printing (A4): iP8500
3 times
Mar 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon PIXMA iP3500 Printer Logo
18 people viewed this question
old marine
old marine
